![]() | Home > Maintenance & Modifications > Addition of a gull wing door |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Is yours a HT or a PU with bed cover? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
r.illingworth67 Member Since: 23 Jul 2023 Location: Malton Posts: 3 ![]() ![]() ![]() |
It’s a HT (hard top?) what is PU?
Cheers Rob |
Pick Up. They sometimes have a bed cover over the rear PU bed, some use an Ifor Galvanised cover, there are also Fibreglass ones too that are common on other PU makes like Toyota Hilux or Nissan Navara etc.
The latter here often being colour match painted. LR Hard Top sides are aluminium skinned from the factory which is then painted. Mine is a HT, it has sliding rear windows fitted and there is a steel strengthening piece to the centre that was removed to do that. As it is in the way. Whose product is it that you are thinking of fitting or getting fitted? ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1910 ![]() ![]() |
I have a feeling this is in the wrong place e.g. L663
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1294 ![]() ![]() |
" I have a feeling this is in the wrong place e.g. L663 Confused "
only a matter of time before you will see Lambo doors on a L663 ......... maybe in 75yrs ![]() and olde Duffenders will be potted in egg-timers. |
