Home > Puma (Tdci) > Solenoid or starter motor? Non-starting issue.
geostrategist
United Kingdom 2008 Defender 110 Puma 2.4 CSW Tonga Green
2.4 TDCi '08
I've not been able to start it for a few days. The instrument panel lights up as it should, but on start there was only a click coming from, I suspect, a start solenoid. Now there's not even a click.
It has had a persistent battery drain for the last dew months, in that the battery drains out over a week or so if not used. Perhaps this is causing something?
I have:
Replaced the battery and re-synced the fob in case it was an immobiliser issue.
Checked all fuses under dash and drivers seat - nothing was blown.
Checked the security and sitting of the various relays
Made sure the battery is fully charged.
Spent hours searching this forum!
Thanks
Post #1036853 8th Jun 2024 3:46pm
MK
I suggest to check (-) points to chassis and transfer case. Puma 110" SW
Post #1036855 8th Jun 2024 4:32pm
BrickBox
Get a long bar and put it on the starter motor body and give it a tap. See if it starts then. Could be a jammed gear. 2008 2.4 110 Utility Station Wagon XS.
Post #1036857 8th Jun 2024 6:06pm
Worth checking for parasitic current draw as well, and that can be something from a relay coil constantly energised or water where it shouldn’t be.
The latter here I found water in a few years ago, will cause a monitor current draw, but enough to bring the battery down to low voltage.
Beyond that, maybe a loose ground or battery clamp in particular the main ground the transmission.
A Multimeter maybe useful here.
Good luck. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1036859 8th Jun 2024 6:53pm
Millerdark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Fuji White
There is a post on how to troubleshoot a drain to earth. https://www.defender2.net/forum/post969511...2C%20there's%20a%20problem.
Post #1036960 9th Jun 2024 6:27pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Solenoid or starter motor? Non-starting issue.
geostrategist wrote:
2.4 TDCi '08
Thanks
How old is your battery ? Try jump start from another vehicle
Post #1037351 13th Jun 2024 7:46pm
geostrategist
Finally sorted after needing recovery. It was the starter motor which has been replaced.
(Photo shows the Land Rover in its natural environment).
Post #1037939 20th Jun 2024 11:47am
That’s unfortunate, but at least you know what it is and that it is now solved.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1037944 20th Jun 2024 12:22pm
