![]() | Home > Puma (Tdci) > Should the engine be holding revs between gears? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1056 ![]() ![]() ![]() |
Your wealth of knowledge is much appreciated
![]() Thank you. I shall look at the brake switch tonight. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17947 ![]() ![]() ![]() |
Don't rule out the possibility that both brake light bulbs have failed. It is not unknown for people to think that since neither light is working it must be a single fault elsewhere affecting both lights, but it is quite possible for both bulbs to fail at about the same time.
After all, the original bulbs came from the same manufacturing batch and have been switched on and off the same number of times and illuminated for the same duration, so it is actually highly likely that they will fail at around the same time. It probably gets less likely as the vehicle gets older since the likelihood that bulbs have been replaced differentially is greater. My policy is always start with the easy checks and work towards the more difficult ones. |
I’ve already swapped bulbs and complete tail lights to completely rule that area out as an issue.
Same result with my old (still fairly new) tail lights. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Just to update this. It was a cheap rear tail light bulb holder causing the issue..! The pins in the bulb holder were touching the earth. Swapped out for genuine bulb holders and a new fuse, revs no longer holding..!
Unbelievable how different things are connected ![]() Thank you so much BlackWolf. Your theory is now tried and tested with positive results..! 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
100% Agree, there is often the most silly thing that is at fault usually often a very basic or low value item, if not careful can be found after buying an expensive part. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Excellent! It's one of those strange Puma things that sound unbelievable, glad it worked. ![]() |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
On a different but related note, do you think the low resistance associated with LED brake lights could result in the same rev hang issue? > 110 XS Double Cab
I certainly wouldn’t rule it out, if you are having issues. Possibly not enough voltage going through the circuit? 2017 5.0 V8 Supercharged RRS SVR
I have LED bulbs in all rear lights except the indicators and it doesn't cause any problems.
I've long suspected that my revs were hanging but having bled the clutch a number of times, changed the clutch switch and 'jumped' the clutch switch pins I figured I was being oversensitive.
Makes you wonder though. Perhaps I'll fit some incandescent bulbs and give it a drive That said I suppose the variable resistance relay does the same job. Perhaps try tweaking the resistance up slightly and see what happens > 110 XS Double Cab |
No, the relay only affects the indicators, the ECM is only affected by the brake lights.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
No. Fitted led brake bulbs when I gotnher 106k aho. No rev hang Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
A failing Clutch switch is another factor that can cause this, and it can happen out of the blue then go away, and then come back or happen a lot causing permanent Rev hang.
If it goes away if you bridge the plug, then you know that it’s at fault right away or you can test it. You can’t just unplug it on a Puma though, it needs an active working clutch switch or a permanently closed circuit. Lots of things get repeated like what I’ve mentioned but it can be useful to those who aren’t aware. Blackwolf - That’s interesting info regarding the two brake pedal switches. I wonder if they engage at the exact same point of pedal travel, or if they possibly engage at a slightly different pedal depression. ![]() Or possibly LR simply wanted two feeds to two different locations, and decided on two switches to do so rather than sharing a single switch. Which makes me wonder if the reason is to detect a different level of pedal depression, a response or reading showing the different between light braking and heavier braking. I know for the brake lights it doesn’t take hardly any travel for the pedal for brake lights to be turned on. One of the reasons I like LED brake lights is the illuminate faster, and that split second if that helps, also more reliable and brighter and vivid. But as usual all personal choices we all have, that’s what I love about LR’s is the face that they can match owner taste. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
The plunger on one of the switches is adjustable on a ratchet type mechanism. I think the idea being they are supposed to be set up to trigger at the same time. > 110 XS Double Cab
