Home > Maintenance & Modifications > 110 rear quarter panel replacement
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
Anyone had the pleasure of replacing the rear quarter panel on the 110?
MY11 puma to be exact.
Had a quote for replace and respray of £3k plus vat!
I am aware of the spot welding and have a brother with one but wouldn't know what is involved.
TIA
Post #1036267 1st Jun 2024 11:04pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
One of those paintless dent removal people would do the job.
Post #1036284 2nd Jun 2024 9:01am
Dinnu
The likely hood that the aluminium has stretched is very high, so a dent repair might be very difficult.
Spot welding aluminium requires a special special spot welder, although I have tried the trick of putting steel sheet metal between the tips of the welder and the aluminium to spot weld with success. You would also need a welder with very large reach.
Hence the easier and possibly as good method is to glue in the new panel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1036297 2nd Jun 2024 12:16pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Britannia restorations changed one prob a year or two ago on his channel, made it look simper, but was not a full replacement Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1036318 2nd Jun 2024 3:43pm
