![]() | Home > Technical > Re-callibrate esc/dsc on puma 2015 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2458 ![]() ![]() |
Unfortunately you will need a specialist diagnostic tool to recalibrate the DSC. The Gap IIDTool can do it, as can dealer diagnostic tools.
What you have done in removing the steering wheel, and no doubt the wiper, light and indicator module to pull the dash forward is disturb the steering angle sensor. This video explains all. The unit on the left with the blue plastic ring is the ring non DSC Puma owners see when removing the steering wheel. The unit on the right with the grey plastic ring is for DSC Puma’s. You will see the grey plastic ring when you remove the wheel. That grey ring is used to indicate the steering wheel position. https://www.google.com/url?q=https://m.you...P_QW192DQV |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
Hang on, if it's "just" the steering wheel sensor I've recently read a thread about a way to set it without a diagnostic tool - can't remember where or how exactly :-/ Something about turning it all the way to one side and then... (?)
I read something similar, will see if I can find it. However I’m pretty sure you still needed a Nanocom to read the sensor value, then adjust the sensor ring to match a full left, then full right lock.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 814 ![]() ![]() |
Is this it?
https://www.defender2.net/forum/topic82783.html I think the bas tool has the facility to Re calibrate as well🤔 |
Indeed that was the thread
RobbyNZ Member Since: 29 May 2024 Location: Auckland Posts: 2 ![]() ![]() ![]() |
I didn’t find that thread but I kind of figured the same thing except I couldn’t find the middle even with 30 half turns from the right lock back to the left
Well found Andy, looks like macfank and I remembered bits of the topic, I.e with and without the Nanocom, and with the gap IIDTool , noting that BAS use a version of that tool for their Remote Remap Control tool ![]() |
