Got it all back together today.. Replaced the vacuum hoses to the brake and clutch servos as well.. In yellow,, 😎..
The non return valve in that line wasn't working, so that's why I was loosing vacuum so quickly after shutting down..
I also got a coat of white on the inside of the wheel arch liner I had off.. Lightens up the depths when you are peering down..
I'll do the other side the same one day👍😂..
Just need to take it for a drive and make sure all is as it should be..
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
