Home > Technical > Ring Aurora DRL
Sybrow
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Keswick Green
Ring Aurora DRL
Hi, I'm trying to wire up the Ring Aurora DRL controller which has 3 wires
- Red to battery positive terminal (through a fuse)
- Orange to positive of one or other side lights
But, can the black be wired to the negative on the side light? (as it says it should be wired to the battery negative?) I've got a Mud piggy back wiring loom I was hoping to use here.
Also, what size fuse do I need on the red wire to the battery?
Any help appreciated!
Post #1033310 29th Apr 2024 8:29pm
Sybrow
Ring Aurora DRL Wiring
For anyone it may help. I got this to work using a mud piggy back loom and a Halfords Blade Fuse with Protected Circuit (FUSE192)
The Ring DRL wiring unit has 3 cables: orange, black and red
The orange and black can be wired to the side light using the two cables from the mud piggy back fuse and the red cable can be wired to the fuse box under the steering wheel using the halfords blade fuse and a 5 amp fuse.
All seems to work OK.
Post #1035053 17th May 2024 10:07pm
