![]() | Home > Technical > Heated Seat upgrade |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
You need to use a 70A relay. You may have to modify the switch. The Defender switch and the identical (but different coloured connector and body keyway) Discovery II switch, don't latch, but switch an earth momentarily. Dyna VT posted an excellent write-up with a diagram on the LRO forum, detailing the fitting of a Defender HFS using the VWP timer relay and a modifed Defender switch. The switch is modfied so that it switches a live pulse to the timer relay instead of an earth pulse, which the timer relay wasn't compatible with. The thread is here - http://www.lro.com/forum3/viewtopic.php?f=44&t=60317 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
For the HFS, Land Rover use 4.0mm2 but, personally, I would probably use 6.0mm2 ![]() The Heated Mirror Kit or Elements should have wiring and/or instructions with them. Personally, I would use at least 1.5mm2, but would probably opt for 2.0mm2 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Defender_Td5 Member Since: 20 Jul 2009 Location: Devon/Australia Posts: 69 ![]() ![]() |
Paul
Thank you for the replies! One more question, when you say 6mm2 do you mean the overall cross section? Such as this: Thinwall cable 6.0mm. Ref: TW6.0 Thinwall cable 6.0mm. Operating temp -40 to +105 deg.C. Maximum working voltage 60v. Nominal current rating 50A. (Derate for long lengths) Resistance per metre at 20 deg. C: 0.00314R. Plain copper conductors (84/0.30mm). Maximum overall diameter of cable 4.3mm. Sold in multiples of 1mtr. Price per metre: £1.49 (£1.79 Including VAT at 20%) Or do you mean the bit I have made BOLD? Which I guess is the actual wire cross section? Sorry about all the probably stupid questions. Like I said electricity is a dark art to me. Regards Rob |
Rob, The sizes referred to, are the cable's Cross Sectional Area (CSA,) expressed in mm2 For the 6mm2 cable in your example - The cable is constructed from 84 conductors, each of 0.3mm diameter, the total Cross Sectional Area of this cable is calculated as - 84 x (0.3 x 0.3) x 3.142 = 5.93838 (or 6mm2) The other dimension they quote is the cable's overall diameter, which is handy to know when buying conduit, sleeving or cable clips. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
explore Member Since: 02 Dec 2011 Location: Crewe, Cheshire Posts: 34 ![]() ![]() ![]() |
Anybody know where i can get a replacement seat element for the drivers seat, in my 2002 Td5 Defender, can't find genuine ones, exmoor say theirs wont work
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 235 ![]() ![]() ![]() |
Land Rover will not supply seat base heaters separately for love nor money, even to dealers etc! You either have to buy a new seat base or whole new seat!
Sorry to be the bearer of bad news! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Good excuse to buy a better seat? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i don't like my heated seats if i'm honest
My little bum heats up to quick! can you get backrest heaters ie keep the kidleys warm? |
Cover the seat and back with a piece of tinfoil - simple physics ![]() But shout it at them in German because life is also terrifying and confusing... |
ok ta ![]() |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1271 ![]() ![]() |
My 2010 Puma lacks heated seats.
I would like to fit them..using this pack http://www.lrisolutions.co.uk/index.php/la...0-110.html Sorry if I've missed out....but is this an east DIY job? Plug n play type of thing? Cheers |
Sorry...easy..not east!!!!
Doh |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
it is not very difficult.
same and cheaper http://www.ebay.co.uk/itm/Quality-MSH50-Wa...3cc97c383c www.newfoundland.gr |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Just been posted. Very interesting.
![]() http://www.defender2.net/forum/topic10705-180.html |
