![]() | Home > Puma (Tdci) > Clutch change. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 787 ![]() ![]() |
More or less what I did... Twice😩🤣.. Because my crankshaft oil seal leaked first time..
I took the opportunity to extend the gearbox breather hose while it was out.. It normally terminates in a void in the bell housing casting but I found it flapping around on top of the box when it was removed.. Check your transfare box output seals for leaks... Easier to sort them while it's out👍 |
I wouldn’t change the crank seal unless it is leaking, they can be problematic.
But they are best left alone I think unless they are leaking. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2423 ![]() ![]() |
Re the master cylinder,
I’m assuming you did not purchase a LOF Powermaster cylinder as you can’t fit one of them until the clutch has done a few thousand miles. Just thought it worth mentioning. From LOF on their Powermaster cylinder * Please do not fit with a brand new clutch until it is fully bedded in- reason being a new clutch has a low biting point, and the LOF master also lowers the biting point somewhat, therefore combined it can be awkward to Drive, hence it is best to bed any new clutch in for 3-4000 miles before fitting, allowing for the biting point to rise up to a middle ground* |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 171 ![]() ![]() |
I would also change the gearbox and transfer box supports. Making my Defender great again. (Or trying to at least xD)
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17867 ![]() ![]() ![]() |
I'd fit an ATB in the transfer box.
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1005 ![]() ![]() ![]() |
I wish I could find a reason to fit one, but even a standard Defender is way above my abilities off road. 2008 2.4 110 Utility Station Wagon XS.
I have seen just a standard TRW master cylinder being advised as a replacement part? Rather than upgrade to the LOF. 2008 2.4 110 Utility Station Wagon XS. |
Had a quote of £1,600 supplied and fitted, inc a 12 month warranty on the parts as the garage is LOF approved.
That’s the road spec clutch bundle and the LOF extreme output shaft. 2008 2.4 110 Utility Station Wagon XS. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Out of interest where did you get that quote? Presumably Promec or Defender Upgrades if they're LOF approved? > 110 XS Double Cab
Yup, Promec 4x4. 2008 2.4 110 Utility Station Wagon XS.
It's interesting as they quoted me the same without the output shaft > 110 XS Double Cab
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 64 ![]() ![]() |
Good Morning,
I am off to france in early June and my master cylinder is just starting to stick. So I thought I would get the clutch changed at the same time. Any recommendations (I have the LOF clutch already).... East Midlands. Regards Chris |
Defender is booked in for next week
![]() Looking forward to seeing the improvements of a new, non rattling clutch and to see what difference a 1 piece output shaft makes to the driveline. 2008 2.4 110 Utility Station Wagon XS. |
