Home > Puma (Tdci) > How do I rev my 2.2 TdCi from u under the hood ?
Two90s
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Keswick Green
I am trying to trace a noise that only appears over 2,000 RPM, sounds like fan belt or ancillaries, but the throttle looks like fly by wire ? There doesn't seem to be a throttle cable. Is it possible to rev the engine while I check for the noise, without asking someone to sit in the cab ? Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci
Post #1034565 12th May 2024 6:18pm
Not possible, the throttle is electronic. You'll need an assistant (or a brick).
Post #1034566 12th May 2024 6:24pm
Two90s
Thank you, I thought so. Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci
Post #1034572 12th May 2024 6:56pm
andy63
im just sorting some bits out to allow me to put the accelerator pedal on a wandering lead.. as I said in a recent post somewhere else .. BW did point out you cant get power take off type control, ie fixed revs using this but all im looking to do is mimic using the accelerator while under the bonnet
Post #1034751 14th May 2024 5:17pm
andy63
Peeing down today and I remembered the acc pedal connectors I had ordered came a while back so I've lashed up my version of a remote acc pedal for when I'm mucking around the engine and need a few revs๐Ÿ‘
Post #1035386 22nd May 2024 11:50am
andy63
Well I tried it today.. Definitely works for the occasional time you need a few revs... Filling the cooling system, and playing with the scope come to mind.. Loads more I'm sure๐Ÿ˜‚๐Ÿ‘
Post #1035571 24th May 2024 2:34pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Thumbs Up
Doesn't it feel scary to press the pedal when the car is facing you? Shocked Laughing
Post #1035846 27th May 2024 8:58pm
Ianh
On a long journey you could put in the passenger footwell and let them control the throttle....perhaps for that extra thrill put it in the back with the children Shocked
Ps looks like you have the Allisport airbox, and a catch can fitted.
Post #1035847 27th May 2024 9:07pm
Zed
Clever stuff. WARNING.
Post #1035848 27th May 2024 9:15pm
andy63
Well it's work in progress.. I can now ditch the long handled mop and keep two hands on the steering rope๐Ÿ‘๐Ÿคฃ..
The picture was courtesy of a lad on another forum.. (cheeky sod.) ๐Ÿ™ˆ๐Ÿคฃ
๐Ÿ˜ณ
The alisport air intake is fitted Ian.. But that's work in progress as well when I find the time..
No catch can, but I did replace the vacuum hoses to the brake and clutch servos๐Ÿ‘
Post #1035865 28th May 2024 5:59am
