Home > Puma (Tdci) > MAF Error and limp mode
Page 2 of 2 <12
andy63
now that helps me get me head round the wording of the fault code, Thumbs Up as im reasonable confident that I know how the sensor works...when I first tried scoping it I couldn't understand what I was looking at, as the trace of an analogue voltage and the trace of the varying frequency of the digital signal are similar, and it took a while to understand what I was seeing ..I did think the reason for fitting a digital sensor was to save the ecu job of converting...
Post #1034555 12th May 2024 4:33pm
mwestcrew wrote:
Wise words from Martin. I think a lot of people see MAF on a fault code and immediately order a new one.
Yes, the EGR can cause the nuisance, phantom MAF codes as well, where the MAF is in full working order.
It’s a pity there isn’t a DTC for the VCV, as that doesn’t have one produced. Which would have actually have been useful. Whistle ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1034556 12th May 2024 4:43pm
andy63
The mass air flow can be used as a feedback or verification of a working egr system.. When the egr is working there should be a corresponding reduction in mass air flowing as the recycled exhaust gas makes up part of the charge in the cylinder👍
That's if you have a working egr system🤔😂
I'm going to do a bit more on the vcv and fuel rail pressures when I get round to it.. In the hope that a given output will have a bearing on rail pressure..
I tried it a while back but without having a load on the engine the vcv duty cycle was tiny And barely noticeable even when the engine was revved
Post #1034562 12th May 2024 5:22pm
Page 2 of 2 <12
