Home > Td5 > Air con condensor supplier |
This came up on a thread in the Puma section last week, which uses the same part, and the conclusion was that there really isn't a cheaper option, unfortunately. I think Island 4x4 were the most economic. Darren
7th Jun 2021 1:21pm |
benspray Member Since: 31 Jul 2014 Location: Norfolk Posts: 159 |
Thanks, I'll take a look, shame as I have 2 frames and 2 fans here now all still ok....
Cheers Ben |
7th Jun 2021 1:23pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2076 |
I did a lot of searching last week and can ouly find them sold as a complete unit - there are a couple of overseas sites on Ebay who suggest that there are some condensers which will fit in the frame for the defender, but I am unable to find any confirmation that they will fit .. and there may be ‘issues’ importing from Europe.
So bit the bullet and ordered one from Island 4x4 who were very helpful and its sitting ready for fitting. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
7th Jun 2021 8:30pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2237 |
I looked into this recently and found a handful of potentially suitable cores from other vehicles. I need to remove my condenser to confirm the fitting sizes before I can work out which one(s) are best suited.
The cores I found are for Subaru Impreza/Legacy, Volvo FH-12 and FH-16, Renault Master/Vauxhall Movano, Nissan Patrol and around £60. Wyvern, can you share links to the items you found? > 110 XS Double Cab > Instagram @simonlanemind |
8th Jun 2021 10:05am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
There are quite a few 'car parts' websites that list ones that they claim to be comparable?
https://www.motor-doctor.co.uk/condenser/l...-5-td5-4x4 https://www.autopartspro.co.uk/land-rover-.../condenser Rgds. Chris |
8th Jun 2021 3:56pm |
robk Member Since: 30 Dec 2015 Location: Zeist Posts: 10 |
Hi Forum,
I am having exactly the same question. The full set (frame, condenser and fan) LR025985 is quite expensive indeed. I only need the condenser, which is not leaking but is missing nearly half the small radiating aluminium bits between the tubing 😀. The sites that offer the condesers (see above) claim competbility, but the pictures provided are different from what is actually installed in my 2004 Td5. Does anybody have an update on this search? BR Rob |
2nd May 2024 8:57pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 797 |
I might be able to throw another option into the mix very soon....
Not going to be cheaper than some of the current options, but is a much more efficient design, using a much more modern core design... and won't start falling apart after 12 months. Currently undergoing sign off testing. With single fan or twin fan mounts - and reuses the original frame (and fan if going single). This is a high quality all aluminium set up. There has been a few changes to design - photos are original prototype. Click image to enlarge Click image to enlarge IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
2nd May 2024 9:55pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2087 |
£120 needs a 15" electric fan. Just have to cut your old plug off and refit.
https://www.ebay.co.uk/itm/115948178433?mk...media=COPY Click image to enlarge Fits well but needs some.minor bending of the AC lines and a 10mm thick washer in the bottom corners. Gassed it up a few weeks ago, ice cold better than its ever been! Instagram @defender_ventures Empire Tuning - Agent |
3rd May 2024 9:40pm |
Thanks for the nice pics. Will however the grill fit to the front? The lower part of the condensor sticks out significantly, IMHO the original grill will not fit at the bottom
KR RK |
18th May 2024 4:55pm |
@porny, seems you were able to replace only the condensor while keeping the original frame.
Where did you purchase the condensor (brand model/part no)? Much appreciated! KR RK |
18th May 2024 4:58pm |
Well needs an AC grill yeah Instagram @defender_ventures Empire Tuning - Agent |
18th May 2024 5:10pm |
Sure, but looking at my A/C grill, that doesn’t provide enough room for that condenser at the bottom just above the front bumper
Rob |
18th May 2024 8:53pm |
Fits fine?
Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
18th May 2024 9:03pm |
Ow, indeed looks like the A/C grill leaves enough room at the bottom for the higher condenser. Great!
@porny, I would still be interested in your route of repairing the (original) condenser. Can you please share the make and model you have used to replace the condenser only. Best regards Rob |
19th May 2024 10:22am |
