Home > Technical > Clock out if true
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Clock out if true
Hi folks, my clock hour needle seems to be out of whack, it sits between the hours when the minute hand is at the 12 o’clock… what, if anything can I do?? @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #1033592 2nd May 2024 10:37am
geobloke
It is unlikely that it is worth doing anything to repair the problem. I suspect it would be a destructive process to get to the hour hand and correct its position.
Three things then that you could do: 1) Live with it. 2) Replace with a like for like gauge. 3) Replace with a clock on another gauge such as the Check Temp 2.
I went the latter number 3 route and fitted a tachometer in the place of the dash clock.
Post #1033616 2nd May 2024 2:30pm
Steve_overland
Think it might be route two … @steve_overland on Insta.
Post #1033619 2nd May 2024 2:44pm
jst
Can't see option 1 working for Steve.
I have a spare one here Steve, exactly the same as yours , you could have a matching pair! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1033621 2nd May 2024 2:50pm
TexasRover
If you turn it upside down, it should be correct again?
Post #1033622 2nd May 2024 3:15pm
markb110
Texas, I have a strange issue with my clock, six months correct, then six months an hour different, then six months later it fixes itself….. Whistle
It’s a feature, I can live with it…. Rolling with laughter
Post #1033634 2nd May 2024 6:12pm
Steve_overland
Just what I need two that a wrong hahaha.... @steve_overland on Insta.
Post #1033638 2nd May 2024 6:31pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Strangely, and annoying for you, but the original dashboard clock in my 1994 300tdi is incredibly accurate and the fingers point to exactly where they should. The only time it ever needs altering is if I have had the battery off or twice a year for the clocks changing.
Post #1033672 3rd May 2024 12:21am
