Home > Maintenance & Modifications > New brackets for Bulkhead to Windscreen frame
Phillywilly72
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Tamar Blue
When considering to upgrade these brackets is it a simple swap or once they are out getting new ones back in is a bloody nightmare with compression required somehow to close up distance between the bolt gaps. Thanks
Post #1033546 1st May 2024 7:54pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
If you are putting in a new Bulkhead to windscreen frame seal they can be a challenge but certainly not impossible - best done with two people so one can push down whilst the other gets the bolts through. If you are not changing this seal then it shouldn't be a problem.
I am just about to put on the new Tredz that Empire tuning do as they look good as well as help to get up onto the roof rack, instead of treading on and scratching up the wings. Defender 130 HCPU TD5
Series 2a 300tdi
L663 5.0 V8
Post #1033569 2nd May 2024 8:03am
Balvaig
I have replaced or refurbished mine on several occasions Big Cry without problem.
Do one side at a time and do not move the car when a block is off to avoid torsion.
I also found that spraying copious amounts of Dinitrol clear into the holes in the bulkhead and blocks, and onto the seals extended the life of the OEM blocks.
Post #1033573 2nd May 2024 8:25am
Phillywilly72
Sounds like if the seal has bed in it should be ok. New gaskets with some flex sealant for added measure and a good dose of rust preventer. Thanks guys Thumbs Up
Post #1033586 2nd May 2024 10:04am
