Home > Puma (Tdci) > Speedo needle jumping
stevendrevers
Netherlands 2008 Defender 110 Puma 2.4 SW Belize Green
On accelerating in 1st 2nd and 3d gear the speedo needle jumps up to 60-90 km/h and dropping back to the expected speed after a few seconds.
driving on the highway 6th gear below 100 km/h no problem, driving > 100 km/h occasional drop and rise of speedo needle with 10 km hour.
(false) Speed level is communicated to the ICU. It alters injection, air etc giving a horrible driving experience (shock wise).
tested the transducer-sensor of another car. didn't solve the problem.
anyone got an idea what might be the issue
Post #1031638 15th Apr 2024 1:48pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I had this problem on the Td5 setup and the wiring had dropped so that it touched the prop shaft and had worn through the wires a bit. I'd be looking for a short somewhere. LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1031644 15th Apr 2024 2:39pm
Philbr110
Speedo issues
Hi, Did you get your problem sorted out?
I have a similar issue that I'm struggling to fix.
Thanks
Phil
Post #1032666 24th Apr 2024 1:58pm
hornet
I just consulted the WSM, the speed sensor is marked yellow. Will have a look later on if that part is present. Could it also be a loose contact in the cable to the cluster? I *think* it's #13, brown/red
Post #1033578 2nd May 2024 8:56am
jst
i would suggest most likley a breakage in the speed sensor insert to the t box its a small box section or the wiring to it Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1033585 2nd May 2024 10:04am
