Home > My Defender > 200Tdi 110
Page 3 of 3 <123
bodstruck
I lent this to my Brother to free up space on the drive and gain political clearance to buy more defenders (that have since been sold)
MOT has run out so it is back with me now. Brake lights had stopped working, luckily that was just a dirty switch.
Main beam also not working. That is turning out to be more challenging Sad
No power getting to the relay for the main beam.
I have managed to rule out the switch and power is getting to the fuse. Just need to trace the nightmare wiring and see where the break is.
Still starting and running great. Shakes like hell at tickover but I have noticed the downpipe is hard against the crossmemeber and the engine and gearbox mounts look poor.
Not got round to fitting the new doors yet, been putting that job off. The rears pretty much fell off but I had sourced a cheap set of puma second row doors and fitted them. Looks a bit odd but fills the hole Smile
While I have it here I am going to simplify the wiring (7 fuse boxes, about 25 relays and bundles of unmarked cable Big Cry .
Then hopefully build up the new galv doors and get it ready for paint. I have window panels and trim to refit in the rear so hoping to go back to being a station wagon.
While my bro had it we both went on a trip to North Wales which was great fun. Short clip of an interesting section that had just reopened. This one with its odd doors and following that is my Puma.
Post #994847 2nd Jun 2023 1:51pm
L110CDL
Thanks for the video clip Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #994916 2nd Jun 2023 10:01pm
bodstruck
Now the decision has been made to sell the Puma and keep the 200 I have been gathering parts ready for it's spruce-up.
Replacement bonnet. I quite like the cargo rails that are on the current one but it looks cleaner without so I have a good replacement with no chequer plate and the sound-proofing intact.
Station wagon sides. The solid sides are OK but I prefer windows. Whilst I had them loose I took the opportunity to tint the glass was well.
Internal Mantec window grilles
New side storage bins (to go over the tub arches)
The high level shelf from the puma will be coming over
Really good set of Puma front doors - elec windows and central locking
Puma rear door, with c/l and high level brake light. I can also fit my existing table to this. And I will sell the new galv one I have in the garage waiting to be fitted.
Replacement wing top for the NS wing which is currently full of filler
Replacement steering column switches
New (to me) cubby box
Diesel heater
Overdrive unit (Roamerdrive)
Still to procure:
Heater locker
Refurb parts for the wiper mech / motor.
Mechanically it is all good, still starts and runs like a dream. Noisy though. And lots of rattles but it looks like that is as a result of some slapdash reassembly when the chassis and bulkhead were replaced. I found out yesterday that the top f the seatbox only has 4 bolts in it right now Smile
The plan is to install the overdrive first, then sort out the rattles, then the steering column switches, wiper stuff and install the heater.
The doors and side panels may need to wait as I would like to paint them before I fit them and it is a bit cold and wet for painting right now. I'll be doing a brush / roller paint job with either coach enamel or CombiColour in a satin finish.
As for the colour, I am torn between Sandglow yellow and Tangiers Orange (or similar, perhaps RAL 2004 as I did on my 90). Decisions, decisions.
Post #1017404 4th Dec 2023 3:52pm
bodstruck
Well, I bought orange paint and a litre of Sandglow to see how it looked and ended up going with Keswick Green Laughing . Satin coach enamel from Paintman. So it will be all satin - green with black roof, hinges and trim. The wolf wheels will be body coloured and painted with fine texture raptor, tinted with the coach enamel to match the colour.
This is the general gist:
The weather is not quite here yet for painting but I have made a start: stripped, sanded and first coat on the rear door (now sanded and ready for next coat); first coat on the bonnet, sides prepped as are the wheels.
Headlining also stripped, cleaned and re-covered in black.
Post #1032003 18th Apr 2024 12:53pm
bodstruck
Still a bit chilly out so having to use the kitchen for painting, which clearly goes down well with the boss. Have to wait until she has gone to bed and then get up early to clear up Smile
Bonnet, side panels and rear door now done.
I had some spare glass from a long gone defender so I decided to experiment with DIY tinting. Bought the kit on ebay. It came out well. I have done the back window and quarterlight, side panel windows and now the second row doors.
I swapped the optimill hinges on my other 110 for the new ones I had painted and intended for use on this one. Cleaning up ready to be stored for a few weeks before I can finish painting the doors and look to fit.
While I work on the bits off the car some mechanical jobs to be attended to. Replacement front diff, front prop UJ and oil seal on the Salisbury axle at the rear. Plan to do those in the next week or so.
Post #1032233 20th Apr 2024 2:47pm
L110CDL
Nice amount of forward progress done there and loving the kitchen work when the boss is not about Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #1032462 22nd Apr 2024 8:57pm
bodstruck
More painting. Front doors were completely stripped, including all locks and window channels. No strictly necessary but even if it is a roller paint job I still want it to be well prepared and last for a while so the extra 30 mins per door seemed worth it.
I treated myself to new OE water shedders and later (2011 on) style bottom door seals. That plus a good internal coating with waxoyl should keep them going for a good few years.
Post #1033268 29th Apr 2024 4:44pm
bodstruck
Bit of a delay before it goes to the garage to have diff bearings etc attended to so I thought I'd kill a bit of time sanding the panels on the car.
Alas the repaint the PO did was very sh!te Sad . Not much sign of decent prep and even though there does seem to be primer under there nothing seems to have adhered to the previous paint. As you can see here, the paint is just peeling away in many places.
That means I can't really trust it not to peel more so all of the last lot of paint really needs to come off. Not what I had hoped for.
On the plus side, at lease I only have to to the front wings, rear tub and roof. Smile Thumbs Up
Post #1034201 8th May 2024 5:18pm
Page 3 of 3 <123
