![]() | Home > Puma (Tdci) > Puma Recall N706; Front axle case flange reinforcement brkts |
| Disneysland Member Since: 25 Apr 2024 Location: Yorkshire Posts: 9
Photo of my front axle. Is this ok?
Picture didn’t upload first time due my incompetence 🙄
Click image to enlarge |
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548
Friction weld, its OK.
Thank you. 👍🏼
| jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 1001
Hi all
Has anyone got a photo they can share of the ones that we should be concerned about? Jim |
Thanks Dinnu
Jim |
Sorry for my ignorance, I take it that a friction weld it the method used in the photo below that is circled in red? If your axle looks like this then your vehicle is not part of the N706 recall?
Click image to enlarge Jim |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
That is correct.
The friction welded axles are fine and not subject to the recall, as it has been alluded to previously of JLR's inability to understand the mantra of "if it ain't broke don't fix it" |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1366
I am sure LR regrets the decision to move away from friction welding, but 100% sure this was cost driven based on what suppliers were offering on the market.
'Normal' arch welding is perfectly suitable for this application, but if you keep seeking the bottom of the barrel with cost being a main driver (like many businesses are ran nowadays), you will find quality issues with welds being poorly controlled and failures happening. Although I can see this being stressful for many, old perfectly fine complete axles are still plentiful and easy to overhaul with quality parts and then easily swapped out. As problems go you can get rid of this one if you are a bit of a hands on defender enthusiast. I still have a 1996 vintage front axle in bits in my shed in France (Paris) available. With some new parts it be totally fine. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
I am reasonably sure that LR doesn't give the proverbial pig's burp about the matter. It may be a minor irritation but so far has been financially insignificant.
The switch from friction to MIG was supposedly made because the FW machine was life expired, and had the MIG been done correctly there would not have been an issue at all. As far as I know the axle cases were not and have never been bought-in, they have always been manufactured by JLR. |
| trevorg Member Since: 28 May 2022 Location: Aisne Posts: 54
This is the weld on mine with the bracket fitted.
| Dibble04 Member Since: 13 Feb 2022 Location: Devon Posts: 34
Just had my N706 recall carried out by my local Land Rover dealer.
I've taken a couple of pictures and would appreciate opinions on the quality of work undertaken. On the passenger side, the new casting is in metal to metal contact with the suspension radius arm. On the drivers side, there is some cracking to the chassis weld above the casting/radius arm. It just doesn't seem right to me....any thoughts? Click image to enlarge Click image to enlarge |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
Thats more of a radius arm bush problem and not workmanship issue.
During the installation of the brackets they only remove the nut from that bolt. The bolt is not removed. I would attend to that crack, also not related to the bracket install. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks,
I accept it may be a bush issue (thanks for that) but surely a reputable garage would have pointed that out and asked me if I wanted it fixed. The car is in for its MOT today and it is likely to fail on the metal to metal issue. On that basis, the dealer has released an unsafe car to me without any mention of it! |
