Home > Puma (Tdci) > African oil!!
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
African oil!!
The truck is due for an oil change, do it every 5k here. Can’t get the good stuff C1, so would you leave it & do it when I can source the proper grade or use a good quality 5/30?
No cat in ours by the way….
Post #1032305 21st Apr 2024 12:30pm
Ianh
If I recall correctly you have a 2.2, but if the DPF / Cat is removed then at least you won’t be getting oil dilution with unburnt diesel due to DPF regens.
I suppose you need to consider how hard and in what environments you have been driving since your last oil change, and the quality of the oil and filter you last used.
So If you used a quality oil and filter at last change, and the environment you have been driving in has not been too extreme, and you only need to drive a couple of hundred miles more until you can get the Correct grade of oil, then waiting until then should be ok.
However that’s a lot of “ifs” and lots of variables, including the spec and quality of the oil you can get your hands on now.
Noting I believe the main reason the spec of the oil for the 2.2 is different to the 2.4 is because of oil dilution due to the DFP. Not having a DPF could mean that the 2.4 spec oil will be ok in your vehicle, I guess checking what spec the Rest of world non DPF 2.2s use will confirm.
If you can post the specifications and make of the oil you can get where you are that would help.
Edit- just found this topic, see half way down post by 90dv and others on Non DPF spec oils, this may help widen your choice https://www.defender2.net/forum/post490085.html
So looks like a non DPF 2.2 can use the WSS-M2C913-B or C standard oil that the 2.4 uses.
Post #1032311 21st Apr 2024 3:12pm
Timcat
Thanks for the reply, yes we have the 2.2 & as always it works hard! Distance to get oil?
Rwanda-Uganda-Kenya….guessing 2.5k miles, the oil I can get a hold of is Toyota branded. The right viscosity but I’m guessing a B grade…..
Post #1032313 21st Apr 2024 3:25pm
Ianh
So if you can confirm your DPF is removed, I.e you have a straight through pipe from turbo to mid section, then the 2.4 oil spec can be used and all you need to check is that the Toyota oil meets that spec . I.e WSS-M2C913-B or C standard .
Post #1032315 21st Apr 2024 3:34pm
Timcat
Yep DPF was removed in Pretoria & had a map off Pete. I’ll check the the spec on the Toyota oil but think it just said B ( never get the actual full spec here!) thanks….
Post #1032323 21st Apr 2024 4:42pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
IIRC the oil is Low SAPS to protect the DPF (burns with low amount of ash). Not sure if it withstands oil dilution any better.
Post #1032335 21st Apr 2024 6:29pm
hornet
Only a used oil analysis provides information, try to keep oil usage below/not longer than 250 operating hours.
I would always go for a high-quality 5W-40 (also suitable for commercial vehicles), because it buffers any fuel input, water and degeneration of the oil due to high temperatures. Oil for Commercial vehicles provide lots of detergents and therefore keeps the engine clean.
Post #1032414 22nd Apr 2024 4:33pm
I’ve got C1 (Castrol) in mine, really pleased with it and runs really nice.
I’d wait and get the proper stuff, unless you need to get it done for a particular reason?
Can Opie get some out to you? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1032453 22nd Apr 2024 8:28pm
MK
You can use any 5w30 ACEA C2, C3, A3/B4, A5/B5, API CF (Toyota).
Ford spec WSS-M2C913-x specifies among otbers, special adfitives for timing chain wear, fuel economy etc. Puma 110" SW
Post #1032651 24th Apr 2024 10:59am
Dinnu
Re: African oil!!
What I learned thanks also to fellow forum members through the Puma 2.2 Compatible Oils
https://www.defender2.net/forum/topic34176-60.html
C1 oil is one of the worse performing oil for the engine, but it will protects the DPF and the environment. Since you do not need to worry about the exhaust treatments, I would right away move away from C1, and even any of the ACEA classifications.
If your 2.2 is working hard and in elevated temperatures, and not too worried about that extra 0.05mpg, I would consider a slightly higher viscosity, such as a 5W40. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032657 24th Apr 2024 12:24pm
HardCharger
Does this also hold true for 2.4 Pumas?
Post #1032750 25th Apr 2024 5:59am
Dinnu
The 2.4 does not have DPF (but has a CAT), so in my opinion C1 is not the best oil for the 2.4. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032752 25th Apr 2024 6:12am
MK
Re: African oil!!
These engines are designed to run the best possible way using rather thin oil, not only for the sake of fuel economy, but to allow for rapid lubrication, oil passing through small oil galleries, main and conrod bearing tolerances,etc. Not to mention the chain driving the oil pump. IMHO I would only use a thicker oil when the engine has lots wear, if at all. To be on the safe side when this engine is working hard at 100C for long periods of tiem you can use a PAO and esther based 0W30 or 5W30. Puma 110" SW
Post #1032813 25th Apr 2024 3:45pm
^^^^ This is true, and you also have to bear in mind sludge build up that then reduces lubrication capability anyway and in fact causes the engine to run worse and harder, with slower lubrication qualities especially when cold.
LR dealers in Europe often use C1 in a 2.4, so that’s good enough for me. (On official invoices).
Eric on here had his in for a Genuine service on his 2.4, and was told it was compatible for both 2.4 and 2.2, with or without a CAT or DPF etc, it’s forwards and backwards compatible for both regardless of any items fitted.
I only use Genuine parts for servicing items too, it’s worth it.
This is just what I do, anyone is of course free to choose what they like.
I find that it’s running just right on the genuine filters and Castrol Edge professional 5w-30 C1.
Performance is good, tickover nice and smooth.
I would say it’s running the sweetest I’ve known, one of the biggest wear points is when cold.
My next target will be diff oils soon etc, but that’s off topic. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1032817 25th Apr 2024 4:53pm
Dinnu
Viscosities apart, its whats in the oil that interest me more. A few decades ago, adding additives rich in molybdenum sulfide improved lubrication and engine life. C1 oil seems to have the least amount of the good stuff, because sulpher harms dpfs and the environment. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032828 25th Apr 2024 7:39pm
