Home > V8 > Differential Pegging 700BHP
SVRDefender90
United Kingdom 1990 Defender 90 V8 Petrol PU Auto Belize Green
Hi all,
I'm just about to place an order with Ashcroft for all my driveline upgrades to handle the 700BHP/900nm torque and I'm stalled at pegged diffs.
The setup is the 5.0 supercharged V8 from a range rover, mated to the ZF8HP-70 automatic transmission. The car isn't abused off road, only green laning with 32" tyres so no serious shock loading should occour.
I'm looking at HD halfshafts, ABS CV's, 3.5 ring and pinions, ATB diff centres and HD flanges. So the question is: Is diff pegging going to be required front and rear? What about trussing the axles?
Post #1032688 24th Apr 2024 5:01pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I've just placed my order with Megasquirt. Give Nigel a ring to discuss. I have gone for lockers front and back with pegged front and back, with 300M halfshafts. 3.5 reverse cut pinion front and standard rear. HD flanges. Will get the transfer box done with 300M shafts etc. as done by Ashcroft.
https://www.megasquirt-v8.co.uk/diff_pegged.php
Post #1032694 24th Apr 2024 6:01pm
Porny
Site Sponsor
I'll be shocked if you get 700bhp from the 5.0 AJ133...
Did a lot of work on those back in the day (actually they all have some of the software I developed on the test beds for JLR in them) - and even in the cancelled GT3 spec with a very different supercharger, we were still at 650bhp and a big chunk of torque. A lot of companies try to overspeed the supercharger with smaller pulleys - but this only gives a small gain, and you quickly get to the point of diminishing returns as the supercharger heats up the compressed air quicker than charge coolers can get rid of the heat.
Also surprised you managed to get the engine running stand alone, as not a lot of ECU's will support it.
However, going back to the question... pegged, 100% yes.
As above I've have a chat to Nige at Megasquirt/Xcess 4x4, or Tom ay Winchester Gears.
As a minimum I'd go pegged ATB diffs, Ashcroft shafts/CV's,propshafts from Gywn Lewis and a Winchester Gears Stage 2 ATB LT230. At least through an Auto box everything else has a chance of hanging on....
Don't forget brakes and steering in the mix... 500bhp plus in a Defender is fun! but you need to control it. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #1032696 24th Apr 2024 6:23pm
jst
i would peg them yes.
for your suggested usage i wouldnt truss the axles. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1032799 25th Apr 2024 1:13pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
be sure to post as much as you can regarding AJ V8 please Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #1032800 25th Apr 2024 1:19pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
As above, I’d go ahead and have them pegged.
I now go for pegged diffs whenever I’m sourcing replacements (from Winchester Gears), regardless of power output. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1032888 26th Apr 2024 7:34am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Some years ago I have changed standard diff gear for HD from KAM with 1:3,8 ratio. They had twice uch of metal, so just the gears itself were much stronger.
With this much power, look for any possible upgrade. It is not good idea to have huge power, and be scared to use it, because of week gears somewhere. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1032906 26th Apr 2024 9:28am
sako243
Out of curiosity why is that? Surely it's just a V8 petrol at the end of the day. Admittedly there's all the variable cam stuff so I guess if you're chasing performance or emissions that matters.
Just my engineering curiosity as I'm currently building my own ECU for the vulnerable old Rover V8 which I know is lightyears away but coming from a background of systems operating at GHz frequencies and separately mega watt power systems nothing particularly phases me. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1032993 26th Apr 2024 10:05pm
Grouse
How are you getting 700 horses out of the RR 5.0 Supercharged ? We’ve got one here in an SVR and that’s around 550 horses - so you’re managing to squeeze an extra 150 out of her - I’m really curious how this can be achieved and by whom ?
Post #1032995 26th Apr 2024 10:22pm
Porny
Site Sponsor
AJ133 has piezeo electric GDI injectors - which aren't the easiest thing to control. There aren't many aftermarket ECU that can do it 'properly'. Making an engine run, is very different to making it run correctly. And then you have variabe cam timing etc etc.
And then in this case the OP wants to run the LR gearbox - really all this needs to be on the factory ECU with all the none required functions turned off. IRB
Post #1033457 30th Apr 2024 10:56pm
sako243
Thanks for that Porny.
It's always fascinated me since designing the electronics side of thing is straightforward. What I'm not familiar with is the actual tuning of the engine. If I ever get the time (or someone interested in part funding it) I'd enjoy building an ECU to run a modern petrol or diesel such as the TDV8. Whilst I can set up the thing to drive the injectors, read sensors etc., at whatever rate is required the algorithm that controls when to fire and how much (for example), i.e. the tuning aspect in my mind, is the big unknown to do well. Ed
Post #1033472 1st May 2024 8:04am
Porny
Site Sponsor
If you are wondering what a big power Defender is like...
https://www.facebook.com/share/p/QkJzdzLXodPuxazm/
680bhp/880nm (650ftlb).
0-60mph in 3.87 seconds.
ATB diffs in front/rear and transfer box. Diffs are both pegged.
Post #1033476 1st May 2024 8:29am
^^^^ Awesome!! Bow down
Post #1033549 1st May 2024 8:18pm
L110CDL
WOW that second video, awesome acceleration Bow down Clayton.
Keeper.
Post #1033752 3rd May 2024 10:10pm
SVRDefender90
Evening all, thank you for all the advice. I've had a chat with Nige from Megasquirt who was incredibly helpful and enthusiastic about the build and we've settled on a package that will be suitable (we hope) which will include pegged casings and trussed axle housings.
To answer your question on power levels and setup:
The supercharger has been upgraded to a Harrop TVS2300 (a 2.3L blower instead of the stock 1.9L) coupled with smaller pulleys and a larger charge cooler to make the 700bhp.
The Defender is being run from an L494 Range Rover SVR system. The entire SVR body loom and powertrain including transfer box and modules have been transplanted to the defender minus the components I didnt need (TV modules, depolyable side steps etc), meaning the gearbox, air suspension, traction control, engine, HVAC, adaptive cruise etc is as it would be in a Range Rover.
Post #1033767 3rd May 2024 11:39pm
