Home > Puma (Tdci) > Panel / hatch under dash
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi all
In the passenger footwell on a Puma there is a hole under the dash which I assume is for the fuse box on LHD models? I assume that there should be some sort of cover or panel that fits on this cut out section? Anyone know what its called or a part number as I have looked all over the internet and cant find one OR is it designed to not be covered?
Jim
Post #1032495 23rd Apr 2024 7:10am
hank
Post #1032497 23rd Apr 2024 7:21am
Dinnu
There are 2 covers under the dash, driver and passenger side. Both should be there. I think same part number, YQH500300, but not 100% sure, maybe you can check with the one that you have that fits either side.
I do not think that Shopee ships to Europe... but I know what my suitcase will be filled with on my next trip to Malaysia Rolling with laughter Then deal with customs later Rolling with laughter .
https://shopee.com.my/Land-Rover-Defender-...f94a2388ac 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032499 23rd Apr 2024 7:29am
jim4244
Dohhh! Thanks guys👍
Jim
Post #1032542 23rd Apr 2024 1:43pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I'm glad there are two (they are the same) because the MOT guy damaged one of the flimsy "hinges" Rolling Eyes Now I remove it before MOT and they think I'm being courteous Laughing
Post #1032577 23rd Apr 2024 6:26pm
Dinnu
I also broke one side of the hinge pins on the cover. And I was being extremely careful removing the cover as wanted to plug an obd reader and get values while driving. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032611 24th Apr 2024 6:13am
jim4244
Bloody hell! They are £75 each! Shocked
Jim
Post #1032615 24th Apr 2024 6:41am
Dinnu
Yup, insane. Hence my teaser with the Shopee link in my first post. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032622 24th Apr 2024 7:44am
Why would your MOT guy go anywhere near the cover? What was he doing to necessitate it?
He shouldn't be touching the cover for an MOT test, so send him the bill for a new one.
Post #1032623 24th Apr 2024 7:52am
macfrank
uh? They plug in their test equipment (OBD port), measuring exhaust parameters / controlling revs, and brake deceleration. How do they do it in the UK?
Post #1032717 24th Apr 2024 9:04pm
UK MoT test doesn't require OBD access, and in fact the tester isn't allowed to remove any panels or covers during the test (other than bonnet, doors and filler flap).
Your mention of "MOT" made me.think you were UK but clearly you're not.
Post #1032738 24th Apr 2024 10:34pm
macfrank
Sorry for the misunderstanding, blackwolf. It's the German TÜV for me, but you can't even spell that Wink
It's interesting to hear MOT doesn't use the ODB port. Since OBD was introduced because of exhaust regulations I thought they'd always had to diagnose if all exhaust-related systems work as they should. My TÜV report states "0 exhaust-relevant errors in fault memory".
So MOT manually revs the engine to do the tests? Here it's done by the test computer which also reads out engine temperature (has to be >80°C), idle rpm and max. rpm. Target values for the Defender are in the system and it compares actual values.
Post #1032791 25th Apr 2024 12:13pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Manual rev with a probe in the exhaust (if they are doing it correctly) 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1032796 25th Apr 2024 12:48pm
Dinnu
I wonder what the German TÜV would read if some of the exhaust related hardware is mapped out of the ecu?
Why I ask? Because locally, the test is more like the British MOT but there are rumors about including an obd connection as part of the test. And I have a 2.2 used in roads where I cannot reach 80km/hr let alone maintain it for a good few minutes. Nuff said. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1032810 25th Apr 2024 3:24pm
macfrank
Good point. So far I know that no fault codes are allowed re exhaust systems. I'll try to find out more.
Also since 2015 they check for existence and fault codes of saftey ECUs/systems such as ABS, airbags (haha). This is mandatory for vehicles registered from 2012. New business model for them what with all the modern gadgets...
Post #1032821 25th Apr 2024 5:20pm
