![]() | Home > Modifications & Maintenance (L663) > New Defender Maintenance Schedule |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Apologies if this has been shared elsewhere, but I couldn't find it...
Has anyone seen the New Defender maintenance schedule? I know the 'headline' service interval is 21k miles or 24 months but haven't been able to find what should be done in which service (A, B etc) and when longer-term maintenance items (timing chains, gearbox oils etc) need doing... It doesn't seem to be in the iGuide and I didn't get any physical service materials with the car Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
I looked on Topix for the service schedule for mine and couldn't find anything, I know for previous Disco 4's and FFRR's there used to be a section that you could download the service sheets for all mileages but Topix seems really bare now unless you pay for access
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
It you go to book a service on the LR website it gives you the list of service types and has a description of what is done at each.
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 ![]() ![]() |
I pay for the emac service plan.
1st service - engine oil and filter Interior air filter Brake fluid Washer fluid 2nd service - engine oil and filter Air filter Interior air filter Fuel filter Brake fluid Washer fluid 3rd service - engine oil and filter Interior air filter Brake fluid Brake hoses Transfer box oil Transfer box drain/filler plug washer Stabiliser link bar nut Washer fluid Hope this helps. |
lrFFM Member Since: 28 Sep 2017 Location: Frankfurt Posts: 74 ![]() ![]() ![]() |
The service schedule depends on the engine. The V8 has its first service after 12 months.
Apologies, mine’s a 250 3L straight six cylinder.
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Workshop manual link, if that helps: https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171 --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 108 ![]() ![]() |
If you go to osh.landrover.com and enter you vin number, you can print out what has to be done for each service.
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3483 ![]() ![]() |
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
on that note, does someone here have the full Workshop Manual for the V8? thanks --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ Last edited by Naks on 16th May 2024 4:08pm. Edited 1 time in total |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1274 ![]() ![]() |
J77 ...... that sheet tells me ...... they don't do much ...... execpt "unload your wallet".
I use an independent, all their guys are ex-JLR, and have the equipment tools/computers. |
There isn’t much more on the second and third either. 24MY 90 D250 HSE, Tasman Blue
