Home > Puma (Tdci) > Aircon / Heated Seats- Puma 2.2 Tdci Utility XS
Dorothy
Firstly Aircon.
Should it get properly cool? Is the single AC button to be used in conjunction with the standard blower? At best we get a cooler breeze. With the usual gearbox/drivetrain heat, it was windows open to cool down.
Heated Seats.
How warm should I expect these? They are of course not multisetting BMW heated seats.
Other standard issues to work on: last bit of fuel leaks on a full tank. Smile Bit of a wobble at higher speeds. Some kangarooing low down. Some 'schlack' in the drivetrain. The mysterious over-revving from 2500-3000rpm appears to have vanished. Front brakes smelling a bit warm.
Post #1031301 11th Apr 2024 8:49pm
DSC-off
When they're working properly the AC is cold and the seats get hot.
A common problem with heated seats is the wire becoming detached from the thermostat.
Details of how to fix here,
https://www.defender2.net/forum/topic76500...d+seat+fix
Post #1031302 11th Apr 2024 9:06pm
Zed
The fuel leak when filling may be the breather hose. WARNING.
Post #1031303 11th Apr 2024 9:18pm
Dorothy
Re: Aircon / Heated Seats- Puma 2.2 Tdci Utility XS
Dorothy wrote:
Firstly Aircon.
Heated Seats.
Cheers I'll get onto that wiring check straight away. Have to get my head around what previous owners did with rear spotlight, re-connect the DRLs and fit a Blue Sea Add-on.
Post #1031323 12th Apr 2024 8:05am
90 Dreamer
we have a 2016 truck and the aircon is always icy cold...
seats are reasonable and work well IMO but maybe not how some would describe as "toasty" albeit I don't have any other reference
Post #1031349 12th Apr 2024 2:34pm
Puma_MOG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
What seats do you have? I had the half leather standard seats first and found they felt a lot warmer than the full leather premium seats I installed after.
As for the AC, I know I will get the details/names wrong but the mixer? could be stuck and while the dial set to the coldest setting, it's actually letting some heat in. It's cable driven can they can get jammed up. I recall mine was quite sensitive on the temp control dial and the slightly touch would heat things up excessively.
Good luck
Post #1031374 12th Apr 2024 8:12pm
90 Dreamer
Yes agreed had the sand XS half leather and now the Premium *or whatever) full leather version ans the heat output seems less but still fine…
Post #1031375 12th Apr 2024 8:51pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Dorothy wrote:
Firstly Aircon.
Too cold sometimes Smile
When you press the AC switch, it'll automatically turn on the blower to it's lowest speed if the blower switch is on 0. You can of course set it to 2 or 3 to get more cold air though it wont affect the AC itself.
Opening the window may actually suck more warm air up from the hot gearbox.
Maybe have the AC fluid renewed.
Post #1031378 12th Apr 2024 9:27pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
With a digital thermometer in the middle vents by the clock my ac goes down to 3 degrees c but it does take a while to cool down the cabin and i can see the temp fluctuate as the compressor turns on and off.
The heated seats.. theres a thermistor in the seat back at the bottom and i broke mine by squeezing it with my thumb (it was stucking in my back and annoying) in the end i replaced it with a random one off ebay and the seat stays on for longer without shutting off - it gets too hot for me :/ 1953 80"
1987 mini city e
2011 90"
Post #1031380 12th Apr 2024 10:39pm
BrunoJ
Norway 2012 Defender 110 Puma 2.2 SW Keswick Green
My aircon blows really cold air.
Overall heating regulation is quite unprecise, and not very effective, for far end of the car, so rear seats passengers will have different experience then driver.
Heated seats are one of worst I ever used. They are diesel-like - few minutes before you really fill something. I guess this is due to quite thick leather. Still better than nothing during winter.
Post #1031571 14th Apr 2024 9:59pm
Millerdark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Fuji White
The aircon probably needs a recharge.
Post #1034018 6th May 2024 10:42pm
jst
macfrank wrote:
Dorothy wrote:
Firstly Aircon.
As above, keep wi down closed to reduce air bring s7ckex up 9vervgbox area that warms and ghen heats the cab. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1034121 7th May 2024 9:06pm
Dorothy
Will get it topped up. If it doesn't need topping up, then theoretically I have a mechanical issue. Laughing Dorothy - 2001 Defender Special Vehicles TD5 Hardtop (Ex Scottish & Southern) Side Lockers, Side Hatches - Poorly chassis and bulkhead. (SORNd)
Ethel - 2013 Defender Puma Utility XS
Post #1034582 12th May 2024 9:04pm
