Home > Tdi > Coolant fluid for a 300TDi
Seabreeze
England 1996 Defender 90 300 Tdi CSW Epsom Green
Hi All,
I need to top up my radiator with antifreeze/coolant. What type should I use, is the the blue or pink stuff, any particular brand?
Thanks
Post #853317 31st Aug 2020 10:58am
htb2
Wales
Mine runs on pink. You need to match it to whatever is in there at the moment, what colour is yours running at mo?
Post #853319 31st Aug 2020 11:14am
Seabreeze
Mine is definitely pink!
Post #853325 31st Aug 2020 11:41am
Bluest
Apparently, colour is not a reliable indicator of the type of coolant in your system.
https://www.opieoils.co.uk/t-car-motorbike...ained.aspx 2007 110 TDCi Station Wagon XS
Post #853328 31st Aug 2020 12:10pm
Seabreeze
300 TDI Coolant
OK, so I guess it is back to the hand book definition: " Use an ethylene glycol based anti-freeze (containing no methanol) with non-phosphate corrosion inhibitors suitable for aluminium engines....."
Post #853329 31st Aug 2020 12:20pm
discomog
If you can afford, drain radiator and block, flush with clean water and then fill with correct spec. That should give you complete peace of mind Smile Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #853396 31st Aug 2020 6:22pm
L110CDL
I use to have the pink stuff and was told it was no good for my engine (300 Tdi ) it had not been in for to long, so the system was flushed out and now i have a very dark green/blue stuff, right for my engine Thumbs Up Clayton.
Keeper.
Post #853447 31st Aug 2020 9:29pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
I recently had the same dilemma, as has been said colour is not a definite indicator of type. As far as I could work out it is a choice of OAT based or Non-OAT based. The main difference being an OAT based coolant will last longer, typically 4 years before needing changing, whereas a Non-OAT based coolant needs changing every 2 years and was used in older engines.
As I understood it there was or is a school of thought that OAT based was not ideal on older engines due to issues with some seals. To be honest I never really could find a definitive answer so I have opted for the Non-OAT based solution and change it every 2 years. Its not a big job and I figure giving the coolant system a good old clean every couple of years is no bad thing anyway. In the end I chose this; Bluecol Antifreeze 2 Year 5l - BLA005.
Not a very scientific approach I am afraid but a pragmatic one for me Smile
Post #853450 31st Aug 2020 9:36pm
zippo87
Scotland 1996 Defender 110 300 Tdi CSW Epsom Green
Same for me - so many opinions and information out there, it had pink, I went with what the manual said - happy to keep an eye on it and do it again. Think it was comma G40?
Post #853459 31st Aug 2020 10:03pm
Mo Murphy
Ethylene glycol is the stuff. Usually blue but not always.
50 Shades of Pennine Grey
Post #853534 1st Sep 2020 9:37am
WarPig
I use this in my Defender 300tdi
Post #854504 5th Sep 2020 9:50pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
My ROW spec 2006 300Tdi came with the pink OAT stuff from the factory (as did all the others) so that's wrong - they are quite happy with either just don't mix the two! I think they moved to using OAT at the same time the Td5 came out, presumably to simplify things on the production line where they were building Tdi and Td5 alongside each other. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #854561 6th Sep 2020 2:13pm
Mdm
TDI uses the regular blue stuff as above
td5 oat red/pink coolant
then you have purple and green for other makes like volvo...go figure.
as long as you dont mix the different types you will be fine.
just keep the strength correct.
Post #854592 6th Sep 2020 7:44pm
Wolfie831
United Kingdom 1999 Defender 110 300 Tdi ST Nato Green
The issue with OAT coolants is when you may have upgraded to Silicone hoses, the Organic compounds breakdown the silicone over time and they WILL eventually fail. Only IAT (Blue) coolant is safe for use with the 300Tdi engine fitted with upgraded hoses.
Post #1031340 12th Apr 2024 10:53am
L110CDL
Yes that is why i changed from pink to blue as it started to delaminate the silicone hose from the inside out Rolling Eyes Clayton.
Keeper.
Post #1031705 15th Apr 2024 9:07pm
