![]() | Home > Maintenance & Modifications > 265 75 16 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3409 ![]() ![]() |
Which vehicle are they on?
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 167 ![]() ![]() |
Sorry..... 110 puma crew cab
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 857 ![]() ![]() ![]() |
From experience, regardless of tyre type, at this sort of size I would run 30-32psi all around and then watch tyre wear. If you rotate the wheels every few thousand miles at this pressure you should get a pretty even/flat tread wear profile that maximises tyre life. If running heavily loaded or when towing I go up to about 34Fr/38-40Rr but reduce pressure back down once the trip is done.
Also need to bear in mind that these tyres are only speed rated (K) to 68mph which is significantly less that the published speed of your truck.
