Home > Puma (Tdci) > Puma 2.2… Can’t start, Compression is there but no diese
Borbarad
Germany 2013 Defender 110 Puma 2.2 SW Fuji White
Arghhhh… 220km the Defender went nearly flawless and now defect after defect….
So, It all started October last with toooo low Fuel Pressure erro (thread in this forum). We replaced the fuel Filter, Fuel Tank Pump, first the valve at the high pressure pump and then the whole ho pump. thereafter it worked again…
https://www.defender2.net/forum/topic89972.html
Then clutch went and we also replace and the output adapter
https://www.defender2.net/forum/topic90742-15.html
Then the Turbo Actuator and a series of Error Messages. Could find anything and the replace meant of the actuator worked…
https://www.defender2.net/forum/topic91590.html
And now back again. Engine cut out, Battery Symbol, Engine, Traction…. All the lights.. and now power.
Error Codes acc. to Nanocom: P0336, P2564, P0642, P0531, P0069, U0401… They all say Electrical
Could restart and it worked, but again an again after a while the cut out, but most it got working again.. and than the main one. Nothing works…
If a try now to start, the engine tries, compressions is there but it is like no fuel (Electric seems all there)…. Arghhhh. Any suggestions… ?
I just cant anymore… wtf.
B
Post #1030893 7th Apr 2024 8:51pm
Borbarad
Ok, Quick search tells me to check Fuse f1 15 AMP and Relay R103 (which is no 7)…
B
Post #1030894 7th Apr 2024 9:03pm
Borbarad
Ok, this morning I pulled the ReBay and exchanged the Fuse. but all looked good…
then I tried to start the engine and it started again…. Woaaa.. but when i tried to accelerate it stuttered again went out and did not run again… It really seem it does not get fuel… or something… and of course when it went off all the same error codes up again…
B
Post #1030913 8th Apr 2024 8:19am
Dinnu
Not sure if I could be of any help, but could it be as simple as a bad earth?
When I replaced my gearbox adaptor shaft, right after starting I had a very weird issue that I logged on https://www.defender2.net/forum/topic73565.html
I re checked all earths / grounds and reset all the error codes and been good since.
Hope you can find the root cause soon. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1030927 8th Apr 2024 9:44am
Borbarad
Yeah… I got it running again reved up to 2k fine and then when release the trottle in went out again.
Before that if was shaking the while wire harness and fumbling on top of the gearbox to see if there is somehwere a loose cable… or the like… so the error must be above the Gearbox, maybe an earth as well
Problem is no that i have a diesel Heater installed… so getting on top of gearbox will be a lot of mess now …
Wonderful afternoon job afternoon work…
B
PS: Took a load of photos above the area of the Transmission housing… Both earth look rock solid there is nothing to move…
Post #1030932 8th Apr 2024 10:36am
Borbarad
So… now i gave it another try…. Only wiegeltet at:
The Maine ECM Cable behind the Engine
The cables across the Transmission
Took a Censored of fotos trying to see a thing bu so far could not figure out /see a thing.
Any how, engine did start, let it run in idle for ca 5min, could clear all Faults… pressed gently the gas… no issues, sounded smoothly as always…
so, I call it a day for now. will have another run at the photos to see where there could be an / the issue….
Any suggestions for hidden “touching” point causing a fault, earthing issue on thoses “areas”
B
Post #1030970 8th Apr 2024 4:57pm
