Home > Puma (Tdci) > 2.2 puma some days quick some days slow.
Page 2 of 2 <12
Daphne
United Kingdom 2015 Defender 110 Puma 2.2 HCPU Fuji White
That’s my next port of call, I removed the inlet manifold it was clear of any soot.
Post #1027752 12th Mar 2024 8:59am
Daphne
Update, took off inlet manifold clean as a bell, I’ve replaced all sensors with genuine also new EGR valve. I’m Still getting EML light but it happens in cycles if when I start it EML is not on it runs sluggish then after a few miles EML comes on and limp mode. If I flick the ignition on and off limp mode goes away and truck goes like a rocket as long as the EML light is on so after the 4th restart the EML light goes out and the process starts again. I’m flummoxed
Post #1028806 20th Mar 2024 8:17pm
Does it have DPF? If so, I’d take a look at that.
Lube your turbo actuator pivots as well, and check the vanes are free manually, it’s pretty much free to check it out.
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1028809 20th Mar 2024 8:29pm
Daphne
Hi
Had the Dpf cleaned but It could still be affecting air flow as I’ve read cleaning is a temporary fix, turbo was a new Garrett last August.
Post #1028810 20th Mar 2024 8:35pm
andy63
your dpf will have a differential pressure sensor fitted..I personally don't know what way to test that but if its working correctly it would flag a fault on the dpf if it was blocked or restricted..
you faults are still related to your mass air flow meter I assuming with a code that indicates low air flow... im always banging on about it but it would be good to have that checked with a scope to see what its actually outputting... I could give you the expected good value off mine, but I have a few tweaks that would most probably make it a little different, so ideally you could do with your own comparison when running well and when in fault condition..
thats where I think id be starting anyway...but your intermittent issue may well boil down to dodgy earth on the sensor..
Post #1028815 20th Mar 2024 9:00pm
Daphne
Just an update, you were spot on found corroded plug under drivers seat cleaned plug and it’s been fine for several hundred miles.
Post #1030884 7th Apr 2024 8:09pm
Page 2 of 2 <12
