Home > Td5 > Lynx vs NanoCom
alexatnd
Lynx vs NanoCom
3 years ago I bought a Lynx unit to use with my 1999 td5 and my 2004 td5. TBH didnt think it gave me that much info, especially on the 1999 td5
The 3 year license has now expired and we're into annual license renewal and was wondering how the Lynx compared with a nanocom. It looks as if you can do more with the latter, is that the case ?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1030050 1st Apr 2024 12:27pm
Ianh
Run the Nanocom emulator and you can compare the functionality with your current lynx tool.
https://nanoint.nanocom-diagnostics.com/index.html?rand=616
Post #1030052 1st Apr 2024 12:45pm
NickMc
Depends on budget but I’d personally, if you’ve a few different td5 vehicles you want to use it on that will work with all system and models I’d browse eBay and keep your eyes out for an older Autologic “blue box” with Land Rover software (£500-2k depending on what manufacturers are on it) or an old “brick” nanocom that’s not locked to a vin. I have nanocom, T4, T4 mobile and Autologic for just defenders and I’d pick up the Autologic every time over the rest, the blue box is out of subscription, but continues to work up to 2017 model all Land Rover and isn’t vin locked. The lynx is just ok and the t4 takes too long and you have to follow along the procedure how they want you to do it, the Blackbox Solutions MSV or whatever it is now was awful in my opinion and I got rid of it, nanocom is handy for taking out and about/fuel map files or travelling.
No one is better than the other at everything, but if I had to have one it’d be the blue box every time, this is my third one and there’s a reason every independent probably has one.
Post #1030302 3rd Apr 2024 1:41am
alexatnd
Now thats good, cant tdo most of that with the Lynx one.
Post #1030615 5th Apr 2024 12:11pm
Ianh
See the TD5 Nanocom page , at the bottom you will see documents re engine ECU, ABS and Alam 10AS support.
https://www.nanocom-diagnostics.com/produc...er-td5-kit
Ps, reading the Engine ECU document it states;
“The ECU was updated in 2000 with the addition of new features which would allow the ECU to have its fuelling and operating system software updated by being reprogrammed through the diagnostic connection.”.
I suspect that’s why there are different diagnostics available for your 1999 and 2004 TD5’s
Post #1030632 5th Apr 2024 1:12pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
TD5 engine ECUs were upgraded from MSB to NNN type with change from eprom to flash memory. With flash memory it is possible to program better/newer or tuned map into ECU through OBD with diagnostics equipment, instead of replacind/resoldering programmed eprom memory. Diagnostics equipment is the same, software in ecu i bit different. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1030685 5th Apr 2024 8:12pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Can you use any of these devices to show RPM?
Also, has anyone installed a digital rev counter? 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #1030933 8th Apr 2024 10:41am
MadTom
With Nanocom look for instrument mode, it works like engine multimeter. For standard use, tachometer instaled in dash is my preferred solution, I use Nanocom in different cars. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1030941 8th Apr 2024 11:59am
