Home > Puma (Tdci) > Oil cooler assembly |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 274 |
If the surfaces are clean and unmarked then the gasket alone should suffice..
I don't suppose there was any sign of gasket/sealer been used when you removed it.. So as long as it clean up OK.. Should be fine.. |
5th Apr 2024 3:47pm |
SilverPuma Member Since: 27 Oct 2023 Location: Devon Posts: 28 |
That’s what I was thinking but just needed a second opinion as otherwise I could be tempted with my usual approach of a film of blue hylomar as a belt and braces, although likely not correct 2010 2.4 TDCI Puma Defender 90
5th Apr 2024 5:12pm |
im not sure about the not correct.... its a judgement call based on experiences..
ill bore you with my last wrong call.. the dreaded crankshaft rear oil seal which I fitted exactly as instructions stated and used sealant sparingly on the areas recommend...my instinct was to use a bit rtv on it as a belt and braces as you say, but I didn't.. and it leaked on the second attempt I just followed my instinct as well as the instructions and used rtv silicone sparingly where I thought necessary and I suppose with a little benefit of hind site, knowing where it had leaked from ... its fine now , so its not straight fwd... |
5th Apr 2024 5:34pm |
