![]() | Home > Technical > ring gear pattern |
Looks good to me. Very similar to my efforts when I installed Miffy's ATB.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6026 ![]() ![]() ![]() |
Is this going to end up like Readers Diffs? 1999 Defender TD5 110
I guarantee no one is ever going to pay for that service...
olistr Member Since: 29 Dec 2022 Location: BW Posts: 69 ![]() ![]() |
Thx geobloke needed confirmation
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 203 ![]() ![]() ![]() |
It just happened that I very recently changed the rear diff center of my Puma 110 for an Ashcroft ATB (P38 differential housing). I had excessive play between the side and spider gears, making a "clunk" noise in some situations, which was annoying as the rest of the transmission is pretty tight.
The ring and pinion were still good after 130K, so I re-used those, saved me from having to adjust a new pinion height and preload in the housing. So basically, only a new ATB diff center with its new side bearings kindly pressed in by Ashcroft before shipping (thank you). Anyway, after setting the backlash as per the manual, I checked the pattern and although it looked good to my untrained eyes, I was not sure. Having driven the Landy since on all type of roads including motorways, I am satisfied that it is neither howling nor whining. And the "clunk" is gone. ![]() Below the pictures of my pattern if you want to compare, similar to yours, so you should be good ? ![]() Click image to enlarge ![]() Click image to enlarge /Mat Last edited by MatLandy on 29th Apr 2024 12:45pm. Edited 1 time in total |
That looks good.
I am also keeping housing , pinion , crownwheel, but my preload with the same shim was wrong |
Excellent work Gents. The ATB in the rear is a lovely addition
