Home > Technical > Defender won’t go above 50
Djmdaniel
United Kingdom 2002 Defender 90 Td5 SW Aintree Green
Hello, i have just had a new clutch and flywheel fitted on my defender 90 td5 2002 and it doesn’t seem to go above 50mph, is this’s normal for a bit or is there something wrong? Thankyou
Post #1030532 4th Apr 2024 8:33pm
Mdm
something wrong if it was faster before the work...
Post #1030534 4th Apr 2024 8:42pm
Djmdaniel
Yes it was used to do about 80 max, any idea what could cause this? Thanks
Post #1030535 4th Apr 2024 8:44pm
Mdm
alas no it could be any things. return to whomever did the work asap and give them chance to check it over
Post #1030540 4th Apr 2024 9:11pm
Ianh
Is the transmission brake binding ? It would get pretty hot if it were.
Post #1030553 4th Apr 2024 10:08pm
jst
it in high i take it? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1030554 4th Apr 2024 10:08pm
Ianh
That’s an interesting idea JST, especially if the transfer box was in Low, the linkage not connected and the lever in high.
DJMdaniel , Have you been going through the gears double quick to get up to speed ?
Post #1030561 4th Apr 2024 10:32pm
NickMc
Did they forget to plug the air flow meter or the vacuum hose to the air box?
Post #1030697 5th Apr 2024 10:23pm
