![]() | Home > Maintenance & Modifications > LR OEM led lights |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i like the river runner sets with the DRL optrion from mobile centre
can't see them warrenting a retro fitted set of LED lights though |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
DJ - Mobile centre do the LR OEM lights in OEM size, and in both clear (as SVX) and coloured versions. They're cheaper than Land Rover too, and Tim's a great bloke.
Remember that yuo'll need some sort of resistor if you go the LED route, to get rid of the 'fast flash' issue. HTH, ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Cheers for that ,I didn't realise that Tim did the larger svx style clear lights, been on to him this morning and all explained clearly, TBo I was beginning to lose the plot a bit.
Tim cleared everything up so it's going to be a full set of rear,clear 95mm led lights which apparently will screw straight into the existing fittings, so a nice easy quick job. So wifey (style guru will be happy) probably not the best for retaining the 'original look' but at least they will be seen from the rear, and if I want to be original I'll use the 90 ![]() I'll post back when I have them fitted, hopefully with pictures. DJ |
Did you get a 60w 4 pin flasher relay ?
I believe that's going to be in the 'kit' that Tim is sending (when I place the order) as I did ask about it after reading some posts here about erratic flashing etc. (not a spelling mistake!) DJ Last edited by d j hutton on 28th Nov 2011 5:30pm. Edited 1 time in total |
Yep should be Tim is generaly on the case and a great guy
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
......thats the big guy.....DIRTY BOY, .....Ken , be intouch, got what you want back in.... Putting Dreams on Drives at JLR Solihull.. |
The genuine kit does not include LED indicators.
I found that out today from Tim, they must be 'normal' bulbs. The Duckworth site lists indicators in the LED kit so I assumed they would be led's by apparently not. Good job you guys are on the case, I've obviously asked the right people. ![]() DJ |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
£500 is hell of a lot of money to pay for a kit of parts that can be assembled for about £220 if you do some research with internet based auto electric suppliers.
The 95mm stop/tail LED lamps can be had for about £28 each, fog light is about the same, reversing light is the expensive one at about £75. Lenses for normal lamp indicators are about £12 each - saves messing about with the indicator relay, but if you want the LED ones are again about £28. These are all Perei light units and are available in coloured or clear. Get the ones with wire ends and fit econoseal male connectors to them, this avoids the need for a link cable which is needed if you buy the lamps with a superseal connector built in - Landrover charges about £70+vat for this ![]() You will need plinths for the stop/tail and indicator lights, the Landrover one for LED lights is LR009773 at about £7 each, note the central hole is smaller than the normal plinths so if you use bulbs for your indicators you will need a pair of standard plinths which are about £5 each and modify the mounting holes in these plinths. |
Here's mine, I didn't bother with the clear lenses and also used normal bulb indicators.
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Nice looking wagon, just the size lights I wanted - hoping they'll be a bit brighter for others to see from behind, its clear for me though (I've been told) I'll be fitting them at the weekend.
I'd agree with that which is why I posted for suggestions and options, I think I've got what I wanted for a reasonable price (nowhere near £570 odd for LR supplied ones thankfully) Pictures to follow next week when all fitted. Cheers DJ Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
what about LED bulbs in standard lenses?
you can get the 360 deg bulbs now so no blind spots |
Too late now I'm afraid I have flexed the plastic (again) Like the truck BT same colour as our one is going to be. DJ |
