![]() | Home > Maintenance & Modifications > Windscreen replacement |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
For £55 fitted by one of the windscreen companies (you supply windscreen & seals) why take the risk? 2001 TD5 110 DCPU in Bonatti Grey
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I've done shedloads !!!!
Is your old one cracked or are you just replacing rubber?? Take off the inner a pillar trims...2 screws each side. Put your foot on the corner of the screen and with STEADY CONSTANT PRESSURE push on the screen (don't kick) and with a long blunt screwdriver, push the lip of the rubber so it comes off the aperture, work along to the other side... It's easier do than write about ! To replace screen use a thin rope, start at the bottom of the screen in the middle and feed it in the lip all the way around. Place the screen in the body, apply STEADY pressure and pull the string so it lips over the aperture, do the bottom first, then the sides, top last...make sure as you pull the rope out, the rubber lips over...apply pressure to the glass following the string, not on where the string is...difficult to explain ! Fairy liquid mixed with water in a squirty bottle is a good tip... Any problems ring me !!! QRZ M8VPF |
Better advice !!! QRZ M8VPF |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18027 ![]() ![]() ![]() |
Thanks Greeni!
I have in the past fitted plenty of traditional fixed side windows etc in Landrovers and I am familiar with the rubber seal techniques, but not done a front 'screen in a Defender before, hence the question.
Because the risk is small and I can think of better things to do with £55 than give it to someone to do a job I can do myself ![]() |
