Home > Technical > Ignition feeds
jst
Ignition feeds
On a puma ignition barrel there is a white and white with orange, iirc, ignition feed.
The white wire is pos II live
The white and orange is pos I live.
What's the difference?
Do both pos I and II keep 12v when cranking? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1029859 30th Mar 2024 10:04pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
The lower switch postitions will keep 12v when a higher pos is selected, if that's the question?
white-orange is 12v for radio etc., white is ignition live, white-red is crank,
https://www.lrworkshop.com/wiring-diagram/...ing-system
https://www.lrworkshop.com/wiring-diagram/...label=S176
Post #1029862 30th Mar 2024 10:40pm
jst
I was wondering if one of those two ign feeds had a greater priority. Ie I need a 12v ign feed that prioritises for a fuel pump and doesn't drop, as much, when cranking. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1029864 30th Mar 2024 10:47pm
PaulMc
This is how the fuel pump is wired in a factory V8 of 300Tdi vintage -
I've copied this circuit diagram for harnesses that I've made for 200Tdi / 300Tdi to V8 conversions.
. Paul.
Post #1029869 30th Mar 2024 11:40pm
jst
I have also taken it from the white feed.
Thank you. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1029871 30th Mar 2024 11:49pm
