Home > Faults & Fixes (L663) > Car switches off after driving in wet weather
4x4man
United Kingdom 2012 Defender 110 Puma 2.2 CSW Orkney Grey
Hi all
I’m getting a little frustrated with our dealership .As they cannot /will not put the effort to find a locate a fault on my car ,and to add insult to the issue they keep trying to charge me for the diagnostic cost !!!!
Basically we live in rural area and a lot of the road round us get flooded 6” to 9” deep . When I drive through these lane (not fast just meter high splash either side) when I get to end of lane /next junction and stop at give way or something . The car automatically switches off .
I then have to restart car
However is I leave stop start disabled it does not switch it’s self off driving through flooded roads .
Does anyone have an ideas and please no suggestions to buy a Toyota or not go out in wet 😹😹😹😹
Regards
Ray 2023 110 Xs commercial D250
2005 D3 HSE (green lane toy)
1983 westwood gazelle 11HP still going strong
Post #1029729 29th Mar 2024 12:04pm
pjm-84
Question
Sounds like stop start is working perfectly.....unless I've missed something?
Post #1029740 29th Mar 2024 3:08pm
4x4man
Sorry my message was a little vague
It’s actually switches it’s self off fully . So I have to put foot on break peddle and press start to restart the car 2023 110 Xs commercial D250
Post #1029746 29th Mar 2024 3:46pm
Probably some primary power / ground issue, loose connection. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1029767 29th Mar 2024 7:02pm
4x4man
Only ever does it when driving through water . Rest of the time the car is fine ? 2023 110 Xs commercial D250
Post #1029783 29th Mar 2024 9:39pm
Ianh
Obviously the start stop system has a fault, and it’s a complex system.
This article gives a basic generic explanation of how a stop start system works and the components involved.
Part 5 - explains the systems involved.
https://www.powerelectronictips.com/unders...derations/
Part 4 - more specific details on the starter motor.
https://www.powerelectronictips.com/unders...ar-issues/
I expect the water is getting at one of the components in the engine bay, potentially a sensor, preventing it from initiating a restart. I.e the wiring / connector to the brake pedal, or it could be the wiring or connections to the starter ( noting on a stop start system the starter operates in a different way to a non stop start equipped engine) , or one of the starter replays or associated wiring and connectors.
What we really need is a workshop manual for your vehicle to identify component location and wiring diagrams, plus a readout of any DTC’s that have been recorded.
From their it’s basic old school methodic fault finding, which I suspect the technicians at the dearlership are not given time to do , or particularly experienced in as they trend to rely on the diagnostic kit telling them where the fault is, and if it’s not telling them they say fault not found !!!
Post #1029795 30th Mar 2024 12:52am
4x4man
Thanks for reply ian & links
I agree it’s the stop start .i do sense the dealer ship don’t want to mess with it ,as its not straight forwards . Each time tested no fault found apparently .
Looks like I have to kick off a bit and try and get them to try harder . But at end of day ,they are not Realy mechanics any more just fitters , no one seems to be able to think outside the box and only does Whst the computer tells them . Just like our wives keep us in check Rolling with laughter Rolling with laughter Rolling with laughter 2023 110 Xs commercial D250
Post #1029801 30th Mar 2024 9:18am
Soup Dragon
Post #1029806 30th Mar 2024 10:24am
BrettMRC
Mine has done this once after driving through deep flood water, (24" +) much like th OP I live in an area that routinely floods.
About 500 yards beyond the flood I came to the end of the lane and the car completely switched off/shut down, all screens off etc, and had to be manually restarted.
I was on the way to the dealership anyway for the idler repair and got them to check it for codes etc but nothing was found.
It's never done it before on since either...
Post #1031952 18th Apr 2024 7:32am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Land Rover Customer Relations answer - "I'm sorry Sir, but your vehicle is not designed to be driven in wet weather. The problem you are experiencing is due to your driving technique and you using the vehicle beyond its designed capabilities......"
Jim
Post #1031971 18th Apr 2024 9:18am
