![]() | Home > In Car Electronics (L663) > SatNav Failure |
| cgardnerma Member Since: 28 Jan 2024 Location: Boston, MA Posts: 11
Hmm. Does the dash display show other things if you change it show Media Player or Driver Assistance instead of navigation?
Google Maps or Waze doesn't work in the dash. Only Pivi navigation.
| graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 80
Also Apple Maps with the latest updates. I'm using Google Maps on the screen with Apple Maps (which I don't like) on the dash until they eventually admit my Nav Unit needs replacing. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
| Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472
Everything else can be displayed - radio, 4x4, fuel consumption etc. It's a bit odd. Can use Carplay ok and the Pivi map will display on the dash. |
| WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 182
If you have an iPhone, CarPlay displays Apple Maps in the centre IP, if you have an Android phone it will display Google Maps using the Google equivalent of CarPlay. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
| ckamps Member Since: 04 Jul 2023 Location: Oregon Posts: 50
Do you mind sharing an image of the number(s) for the part(s) that the dealer replaced? Better yet, a photo of a portion of the work details. I have a 2021 D90 First Edition with similar issue. When attempting to use built-in Nav, it states " Please insert USB drive containing map files". Using the latest map files on a properly formatted USB A drive failed with the 0% message followed by the failure and try to reinsert USB drive pop up error message. Since I have another month or so of the factory warranty, I'd like to get the issue fixed. Thanks! Click image to enlarge Click image to enlarge 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
Took 3 visits to the dealers and a video conference with JLR tech to fix mine. It's a quick fix if they just replace the Nav unit but they wouldn't do that until all other options were tried. In the end I think they re-flashed the firmware in my Nav Unit but the details I managed to get from the dealer were sketchy.
It should be a pretty well known issue by now and they should have a decent repair scheme worked out. I'd get it reported ASAP. If you can show them the fault before the Warranty expires then they have to honor it as a warranty repair. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
| EdJ Member Since: 11 Jun 2021 Location: London Posts: 32
Hi all - apologies for the thread resurrection but I came across this after some googling as I have the same problem on my 2024 Range Rover. From the responses, it looks like it’s a dealer fix but I just wanted to check if this was still the case (as obviously it’s a complete pain to have to take it in!) Thanks in advance!
This issue with our 2021 D90 First Edition mysteriously got resolved after a regular Pivi software update was applied. 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
Thanks for replying. That’s indeed encouraging. I wonder when the next update is going to happen….
| All times are GMT |
