Home > Td5 > How to find out/see if an ECU is remapped?
AJC
I have just bought a D2 commercial, I have absolute zero history for it.
I have just driven it down my farm road and the thing flies! I definitely think its remapped, but does anyone know if there is a way of telling apart from removing it and sending it to a tuner.
thanks
Post #797272 8th Oct 2019 3:41pm
excossack
Maybe depending on the age does the ECU look likes it been opened and resealed with sealant?
Or the turbo has extra turns/threads showing on the pushrod? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #797285 8th Oct 2019 5:35pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I suppose you could get one of these GPS apps that calculates your 0-60mph time? If it’s noticeably below what a stock Td5 is capable of, then yours will have some form of remap! Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #797288 8th Oct 2019 5:38pm
Zed
Get in touch with Jose @ Inside and ask him if he remapped it.
If not then ask him to and then it will really fly!
Post #797293 8th Oct 2019 5:57pm
You could plug in a nanocom or other ECU reader, and see what the file map name is,
Chances are if it's been re-mapped then the new programmer would have called it something else other than "sthle022-sttlp010.map" (this is one of the ones for a defender)
But.. they could have kept the name a factory name to make it harder to trace if it was mapped when under LR's warranty, so a dealer couldn't tell...
Post #797311 8th Oct 2019 7:27pm
AJC
Thanks chaps, I did think about looking at it to see if seal had been broken.
a friend has a nanocom so i'll try that and see if it helps
Post #797354 9th Oct 2019 6:52am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
In older typ engine ECUs marked MSBxxxxxx (x is a number) the remap was only possible by exchange the memory chip inside. Mostly the new chip is in a socket. The ECU had to be opened for remap.
Newer ECUs marked NNNxxxxxx (like NNN00120) can be remaped with diagnostics equipment. You can download the map from ECU with Nanocom and compare the file with original map file. Or ask someone for this comparsion. Often remap file in ECU is encrypted, standard file is not encrypted. It is possible do decrypt these files. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #797369 9th Oct 2019 9:29am
Waka56
Germany
I know that this thread is old, but since I have the same question, I bring it up.
To download the map, you need a nanocom or forscan can do it also? I wanna find out if my EGR as been mapped out before I replace it.
G'day Y'all Making my Defender great again. (Or trying to at least xD)
Post #1029713 29th Mar 2024 10:06am
