Home > General & Technical (L663) > New defender questions
Bobbobbobbob
Hi, looking for some help on a couple of things. The tailgate on my 90 doesn't seem to have a 'catch' on the door mechanism which keeps it open on a slight slope. Are they all like this or has anyone found a nice solution to it?
Also, the driver assistance defaults to high every time I get in. Anyone found a way to reprogramme that with the IID tool. I plan on ordering one soon.
Thanks
Post #1028344 17th Mar 2024 1:57pm
lightning
For the rear door, open it to the position you want, then give it a little push back towards the vehicle immediately and it will lock in that position.
My Driver Assistance defaults to "medium" every time l use the vehicle. lt's only ever intervened twice in 10,000 miles. Both times at the same road junction when l have driven up to the centre line to turn right and it probably thinks l am going to have a head on with the cars coming the other way.
However l would also be interested to know if it can be set with the GAP tool to remember the last setting, as with the stop/start function.
Post #1028366 17th Mar 2024 6:05pm
Bobbobbobbob
Thanks!
Post #1028367 17th Mar 2024 6:07pm
Mrburt
Driver assistance offers a degree of customisation.
One long press on the steering wheel button will give you access to the customise section on the main display.
Set your preferences for each assistance system.
After every start up all you have to do is press the steering wheel button twice in quick succession and this will then hold your settings (customise) for the duration of the journey/ignition cycles.
Hope this helps, once set up it really is no big deal every start up IMO.
Post #1028387 17th Mar 2024 9:21pm
DrRob
Which "steering wheel button" are you referring to Mrburt? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years πŸ˜‚
1949 80" - still in family since 1975
Post #1028440 18th Mar 2024 10:46am
Bobbobbobbob
Yes I found that too thank you. It's the circle button next to the diamond. I would just really like not to have to do it every time.
Post #1028464 18th Mar 2024 12:33pm
medallionno3
It’s a legal requirement to have these features to default on now and is the same for all OEMs
Post #1028491 18th Mar 2024 4:36pm
Mrburt
Attached, hope this helps,
Post #1028530 18th Mar 2024 8:10pm
DrRob
Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1028538 18th Mar 2024 8:32pm
