Home > Technical > need help identifying part number
frogg
Does anybody know what the part number is for these push-in trim nuts?
They are used to attach the mock cappings to the early front defender pull-up doors.
They are possibly two-piece, where the clear part is a push-in nut and the black part is a fir tree of some sort.
The outer diameter of the translucent part is about 8.5mm.
Post #1028377 17th Mar 2024 7:33pm
frogg
It looks like the clear plastic part might be MWC9917?
"LAND ROVER DEFENDER 90 110 130 SNAP SACK RETAINER CLIPS SET"?
Except MWC9917 is 16mm. The depth of these appears to be 13mm.
There appears to be snapsac sealing sleeves of different depths:
"Snapsac' sealing sleeve, for 8.5mm panel hole , depth 13.7mm. General application" (12288P)
but what is the fir tree portion?
Post #1028379 17th Mar 2024 8:50pm
frogg
Censored ...I took a chance and ordered MUC3186 ( trim clip )
It is perfect in every dimension EXCEPT the distance between the head and the base of the trim clip.
MUC3186 is 0.75mm wide, while the mystery part is 1.5mm wide.
Does anybody know these trim clip part numbers?
Post #1029854 30th Mar 2024 9:40pm
Not sure about part numbers but possibly try eBay U.K.
www.eBay.co.uk
Usually most things will be on there, if you still can’t find anything in detail try asking the seller on there for dimensions?
Sometimes part nos are updated also. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1029860 30th Mar 2024 10:19pm
