Home > General & Technical (L663) > Door Blind Spot indicator
C&M
I've had my Defender 110 for a year next week and only just realised I don't seem to have the Door Blind Spot indicator that I thought was included in the HSE. ( I happened to be watching a review of the V8 and the guy mentioned it as a cool feature).
there is a blanking plate on both the drivers and passenger door where it looks like it should be.
therefore I assume this got dropped off the spec due to supply chain challenges?
also I am sure there was meant to be something for the rear passengers if they open a car door and a vehicle or cyclist is approaching. Again, I get nothing.
was I dreaming it or is it just another thing missing from my vehicle?
Mark Defender D250 HSE
Dender 110 XS - sadly gone
VW Polo
VW Caravelle - Gen 6
Post #1028122 15th Mar 2024 1:40pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
My MY2022 SE has the small warning screens on each door to warn about cyclists etc so maybe it was one of the things that got dropped Neutral Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1028182 15th Mar 2024 7:40pm
C&M
Ian
I have checked my door and I have what looks to be a blank plate near the electric window controls.
mine is a MY23 HSE so looks like it was another hit not mentioned by the dealer Sad
I am assuming its automatic and you dont have to set it up - grabbing at straws Big Cry
VW Polo
Post #1028199 15th Mar 2024 9:04pm
whiterdesign
I have it , but I believe it was dropped completely on 23.5. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1028212 15th Mar 2024 9:52pm
Hairy Dan
C&M wrote:
Ian
Mark
Yes that's where it is on all the doors next to the window switch, no setting up it just works Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1028234 16th Mar 2024 1:03am
carltb
 2015 Defender 110 Puma 2.4 DCPU Corris Grey
My 24 model HSE is also missing this feature.
Is it something that is possible/viable to retrofit? Does it run of the same sensors as the regular blindspot assist which I do have? 2025 Defender 130 V8
2025 Defender 90 D250 (wifes)
2024 Defender 110 p400e HSE (sold)
2015 Defender 110 Double cab
2004 Defender 90 Td5
Post #1028273 16th Mar 2024 3:42pm
Hairy Dan
I seem to remember (I think) Marco (mmbanf) asked me about it and he looked into retro fitting it but decided against it. Cheers Ian
Kielder 4x4 Safari
Post #1028274 16th Mar 2024 3:49pm
carltb
The part 14C714 seems to be the thing. But are there connectors for it already in the door is the question...
https://parts.jaguarlandroverclassic.com/p...and-rover/ 2025 Defender 130 V8
Post #1028275 16th Mar 2024 4:00pm
Paladino
The connectors are already in the door. Blind spot indicators are different for the left and right side
Post #1028597 19th Mar 2024 9:14am
inith5
Germany
I've already thought about retrofitting. The part numbers are LR098327 for the left side and LR098321 for the right side. I also saw something in the CCF list (MultiCAN-680 ClearExitDetectionSystem- Not fitted) but due to lack of time I haven't made any progress with it yet. Thanks to Paladino we now know that the necessary plugs are already there, although we don't know if this is the case for all MJs. What still needs to be clarified is whether the covers for the blind spot indicators have to be changed or whether a suitable hole can be cut in the existing covers so that they can be inserted. 23.5MY Defender 110 D250 HSE
Post #1028662 19th Mar 2024 6:13pm
Hairy Dan
I can confirm that MultiCAN-680 ClearExitDetectionSystem is marked as Fitted on my CCF
There are also the following settings in the CCF but not sure whether they relate to the same thing Thumbs Up
MultiCAN-644 SmartExitRrPassDoor
Fitted
MultiCAN-644 SmartExitRrDrvDoor
Fitted
MultiCAN-644 SmartExitFntPassDoor
Fitted
MultiCAN-644 SmartExitFntDrvDr
Fitted Cheers Ian
Kielder 4x4 Safari
Post #1028663 19th Mar 2024 6:21pm
inith5
Germany
Ich habe es auch gesehen und hatte den gleichen Gedanken, ob sie damit zu tun haben
they are set to "not fitted" for me 23.5MY Defender 110 D250 HSE
Post #1028672 19th Mar 2024 6:46pm
Paladino
I don't think that you can cut holes - the trim with the clear exit option has the place where you clip the leds.
Post #1028715 19th Mar 2024 11:08pm
carltb
I found 4 sets at a breaker in my country which I ordered. Both new covers with all the correct buttons and switches for my car plus the Clear exit indicator with cable in them already. Total price for all 4 doors less than £170 so worth a try..
Will see how I get on. Hopefully my iid tool g3 can handle the simple coding. Thanks a lot for the CCF info in the thread.
The cover piece was what was giving me a headache. Look how many variants there are
part <111C92
at
Must be 100 different ones... 2025 Defender 130 V8
Post #1028893 21st Mar 2024 7:39pm
carltb
Update.
Ok. So I can reveal that not all cars have the connectors in the doors for the Clear exit indicator. Mine doesn't.... Maybe I should have checked before buying the parts Laughing
If anyone that has the connector is interested in them let me know.
My car was built autumn 2023 110 p400e HSE with all options (well, obviously they skipped some...).
My door
Compared to one with connector. Should be to the right on the white bracket or around there. Wasn't hiding in the loom either on mine.
Post #1029731 29th Mar 2024 12:28pm
