![]() | Home > Puma (Tdci) > Coolant Hoses |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 835 ![]() ![]() |
I think the main large bore hoses from engine and around the radiator are about 35mm int Diameter. not sure about the smaller ancillary/heater hoses but if you can wait for about a week ill tell you for sure as I have a full set of the original rubber hoses off the 2.2 in a bag in the loft at home...I replaced all mine with silicone but kept the originals...
when I get home ill have a look if you don't get a firm reply from someone else before that.. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8477 ![]() ![]() ![]() |
Self amalgamation tape, inner tube snd cable ties plus jubilee clips. Cheers
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
Thanks Andy that would be much appreciated.
Hi.. Just home last night and remembered thisππ..
Had a look and the hose set basically consists of two main diameters.. The large bore ones are 33/34 mm And the smaller 17/19mm.. Those are just measuring the hoses as they are nowπ ![]() Click image to enlarge |
Many thanks - much appreciated
Meant to ask - is that internal diameter? |
Sorry.. Yes.. Internal.. π
