![]() | Home > Technical > Koni or not |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 858 ![]() ![]() ![]() |
I have Koni on my 110.... Seem to be pretty good... Adjustable to suit your requirements... these are my second set the first set suffered corrosion
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
Avoid terrafirma. They are
![]() If youre on road and not doing alot you dont need Konis. Buy Old Man Emu, best value upgrade. To be honest with the low mileage just get regular OEM |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
The Britpart celluar dynamic shocks are a good budget shock. |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 227 ![]() ![]() ![]() |
I've been running Britpart shocks for the last 8 years on various land rovers be it the cellular dynamic and the Supergaz ones have to say been very impressed with them yeah there cheap but they really aren't that bad value for money wise and if your doing low mileage definitely worth considering 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8324 ![]() ![]() ![]() |
i think the Koni are over rated for the funds personally, if it was gooing that far i would have them built for me.
Old man Emu are a great shock, pick duty to suit your needs. personally i wouild avoid Britpart and terrafirma. in my experience neither of them last very long at initial performance Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MCGreen Member Since: 24 Feb 2024 Location: Worcester Posts: 12 ![]() ![]() ![]() |
Sorry to hi-jack thread a little
![]() I have my Defender booked in for OME shocks in April. Question is which version should I get? I am assuming Light - Medium based on below Road use mainly. 2012 Defender 90 HT no rear seats, Standard hight, 18" wheels with BFGoodrich 265/65 tyres Aluminium Storage draw and chest covering all the floor space. (usally empty) Flatdog Roof rack always fitted. NAS Step and 18" spare mounted to door(ORE carrier on wish list) In the Summer I have Tentbox Classic fitted. Thanks in advance. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
I'll start with the OP with my two penneth
IMO for you if you are happy with the current ride then don't swap. Just get a newer standard set up. I've Run a few different kinds ands a fair substitute for standard is the Monroe adventurer it's a reasonably priced gas damper. The Britparts (Cellular - Supergaz) I've seen and heard no major horror stories and the CD's i have on the series seem to be coping fine. Terrafirma started really well I ran a set of the original's (when they had metal dust shields) All terrains and they lasted for years, also the older Big bores. It went a bit wrong and IMO they cheeped out. A brand that seems to have disappeared is DeCarbon Always had a good ride with them. For the money them I wouldn't have Koni just toooo much for what is a damper that should be about £100 cheaper. For what koni want then I would be looking at Fox's instead. At least you could re valve them to get them spot on. As for McGreen then IMO for 90% of what you do then the Light medium damper will be fine. Granted when loaded up with the tent the HD on the rear would be better but you compromise for the rest of the time. It's been a few months running my current OME setup and to accept the slightly firmer ride when unladen, means that when full of camping gear and a trailer on the back means it handles lovely and ergo safely. I do like the quality and the performance but IMO you've got to be thinking this is a setup for above standard where you now that standard stuff you would back off as the ride is compromised or you have boiled the standard dampers, the OME would be just happy carrying on. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Personally I'm a big fan of Koni....
One of my Three go two brands - Koni, Fox and Tractive I've used Koni on everything from standard Defenders to heavily loaded camper conversions - and are adjustable (off the vehicle). On your Defender I'd run them all the standard lowest/softest setting (although again like fox they can be revalved) Combined with larger rear anti roll bar (25mm) your Defender would handle very well. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
