![]() | Home > Puma (Tdci) > Defender Hinge |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
New hinge.
Best to regularity grease them externally with spray grease, though that isn’t even a perfect way of lubing, but helps a lot directly into the hinge pin joints. Regardless, they all eventually wear, but slows it down a lot. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 13th Mar 2024 8:43pm. Edited 1 time in total |
| BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1107
As above. Thankfully they’re easy and cheap enough to replace. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
| Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 176
Yes just ordered one ….. plus Keswick green primer/paint/lacquer
| hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 |
Before fitting, you can drive out the tapered pin, cut a thread and insert the grease nipple. Alternatively, drill a hole to be able to lubricate it when the door is open (conical style greaser)
https://www.offroad-monkeys.de/produkte/la...r-defender I just remembered that there is a very practical tool that I used last night to lubricate my joints with enthusiasm: http://www.kruemmeloffroad.de/Kardan%20neu%20text%20I%20.jpg |
| Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 255
There's a diy modification here you can do to help grease the hinges.
https://www.defender2.net/forum/post707394.html#707394 Courtesy of LRA, who was inspired by lighteningtweeds. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
Great...thanks all.....
I forgot about that door hinge mod - one I shall have to do that sometime.
Is there any chance one of the smallest grease nipples would fit in there in that location if a small thread was tapped? I’m tending to think that clearance room isn’t available and 2mm would need to be bigger to fit one.. So the 2mm hole alone may be best, and inject. I’d imagine a small nipple would need say 5mm clearance and that’s very close or not quite enough space. I have a feeling it’s too close, with the door closed to do that, but would look neater than an external grease coupling visible to the exterior. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2530
Given you would not need to inject grease that often you could get the smallest grease nipple possible , drill the hole and tap a thread in it. Then screw a nipple in to grease then immediately after remove the grease nipple and screw in a blank stop to seal the threaded hole.
But in my view the 2mm hole left as is and a needle coupler or adapter on your grease gun would be easiest, or get that chainsaw grease gun LRA highlighted. Its not like it’s going to get so hot that the grease leaks out , or wet enough for water to get in. |
Very true, I guess the very small 2mm drilled hole would take a pressurised spray grease straw as well as the chainsaw grease applicator.
Or a needle applicator simply on standard grease gun. I was just out of curiosity wondering if there was clearance for say an M4 or M6 straight nipple, a lot of its height would be removed by its threaded section the external nipple section height I’m not sure what that would be. I guess something like blue tac could go in the gap to see what the gap is there available. Seems a bit sketchy the technical drawings with the dimensions that I could see when having a quick look. What are the smallest sizes? M6 seems common (probably a bit large) there seems to be some m4 Chinese offerings. There is 1/8” BSP, which seems around the smallest. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028
1/8" BSP is considerably larger than 6mm.
1/8" BSP OD is 0.383" (or 9.7mm if you're French or under 50). |
BW - I was hoping you may see this thread - do you know what sizes are the smallest grease nipple couplings are?
The ones on the GKN UJs are quite small, the actual straight coupling that goes into the 45 degree housing. I’d imagine they may be imperial sizing, or a combo of both possibly knowing some LR parts. 1/4unf is near m6 Probably best for simplicity to just stick with the tried and tested method LRA mentioned with the 2mm hole. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
M3 seems to be the smallest, must be a very small hole to get grease through though, however I think the thread length at circa 5mm will be too long for the thickness of the hinge plus the protruding nipple will be circa 10mm long.
I don't think the thread size is the problem, rather the size of the coupler part of any nipple.
Given the hassle of tapping a shallow blind hole you're much better off with a plain hole and a chainsaw greaser. |
Yes, I think that may be the issue it’s too close.
There are some hinges on the market that has an external grease point on the exterior to the lower area of the hinge pin, I seem to remember they were very expensive, I know they were posted on here at one point. I can’t remember who made them, I think it maybe from Nakatanenga or somewhere similar. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
