Home > Off Topic > Unreal scale model Disco |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
yep thats it its really a td5
25th Nov 2011 8:40pm |
IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117 |
You're probably right. But if you want to have a 110 you can probably get one custom made. Don't ask me what it would cost, but i'm sure it won't be the cheapest thing. This guy does custom bodies: http://offthegridrc.com/ Killer, your 90 looks very nice . You should post up a build thread |
26th Nov 2011 12:31pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3140 |
I found some videos of 110 versions, so someone is making them... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
26th Nov 2011 12:33pm |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
Might try and stick a Defender body on my 4x4 brushless buggy at some stage.
It came ready built but I've had to customise SO many bits to stop it falling to bits - slightly overpowered methinks! Very fun when it's working. A bit like a Defender really! Defender 110XS SW gone... now VW California 180 4 Motion. |
26th Nov 2011 6:30pm |
yer just get the right scale shell and you will be away
26th Nov 2011 6:52pm |
It's RC4WD that makes the kits. I won the D90 Gelande chassis from RC4WD last year and have a bit of mixed emotions about it. It's mostly metal parts and looks quite scale which is nice. But you will need to get harder springs because the standard one cant cope with carrying the cab and standard electronics. Let alone a roll cage, roof rack etc, Also you will need some decent prop shafts because the standard ones fall apart if you just look at them. Other than that they are great fun |
26th Nov 2011 10:08pm |
alot of money the price of a decent looking one i recon you could by a real 90 say 200tdi for the same price oh well all good fun
26th Nov 2011 10:40pm |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
Mine was one of the early (and more expensive) kits that came with the steel propshafts. I think you can still get them as a cost option. Cracking kit |
27th Nov 2011 12:37am |
Where can i swap |
27th Nov 2011 1:43pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Where do you get the body from ? And those little bits, like headlights, grille, do you make all that or you can buy it ? If so from where ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
27th Nov 2011 2:01pm |
27th Nov 2011 2:22pm |
