![]() | Home > Wheels & Tyres > Wheel nut thread |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582
Googled Defender wheel stud size. First hit was Wrightons. which I nicked this from Brendan |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
It's M16 x 1.5. Darren
Too slow Darren
Brendan |
Ha! I found the same reference as you but was cross-checking with another source
| MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548
Thank you guys....hadn't even thought if google! First thought was here (I reckon that's a good thing?)
2011 110 XS DC Stornoway Grey |
| RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693
M16x1.5 is difficult to get hold off, the usual size for studding etc is M16x2.
I gave up looking and use M16x2 for my spare wheel mount and I'm meant to be an Engineer, but we rarely use metric threads because they are |
m16 x 1.5 threaded bar available here
Brendan |
It's black bar, not Galv or plated. 130 Puma HCPU with an Artica 240LR Demountable Camper
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
So why didn't you make your own, or use a contact to run one off for you? Treat every day as if it is your last....one day you will be right!! |
I didn't need to get anything in the end! I just shifted the wheel over very slightly in the back so the bar now goes through one of the wheel nut holes, rather than through the middle & using the circular plate to hold it. Then just used the locking wheel nut to hold it in place. I hope it doesn't upset the balance too much!
Mind you, maybe it'll sort out the leaning to one side my truck has at the moment 2011 110 XS DC Stornoway Grey |
