Home > In Car Electronics > Difference between Defender 2.4tdci & 2.2tdci
Landy addict
Hi can anyone help out here I have tried finding info on here without success, I believe that information available in the Land Rover systems for a Defender 2.2 or 2012 onward can be a lot more. I was thinking on a new entertainment system & saw this
Land Rover Defender 2007- 2016 10″ stereo upgrade with Apple CarPlay, Android Auto, DAB Digital Radio.
2012-2016 models with the large grey multiplug also get Enhanced Off-Road & Performance Gauges.
Upgrade your Land Rover Defender Vehicle radio with the HEIGH10 UN1810E-LR1 10-inch infotainment system featuring Apple CarPlay, Android Auto and DAB Digital Radio. Retain all OEM features and vehicle settings. 2012- 2016 models also get enhanced off-road, performance gauges.
Vehicle Performance (2012-2016 models)
Speed
RPM
Current/best 0-60mph time
Current/best 60-0mph brake distance
Current/best 1/4-mile time
Vehicle Off-Road (2012-2016 models)
Pitch
Roll
GPS coordinates
Compass
Altitude
It seams these are not available in my 2009 Puma is there a way to upgrade my Defender to be able to use these.
Post #1026997 6th Mar 2024 11:16am
Naks
"Enhanced Off-Road & Performance Gauges."
I've never seen these in a 2.2 Whistle --
Post #1026998 6th Mar 2024 11:26am
Landy addict
It isn’t on a display on the Defender but it looks like this unit can activate it from the Land Rover system to use it on its own screen as below shows, I think that is how it works could it be that the software is in there for other models such as Range Rover or Discovery in the Land Rover
Post #1027003 6th Mar 2024 11:57am
Zed
Re: Difference between Defender 2.4tdci & 2.2tdci
Speed
RPM
Pitch
Roll
GPS coordinates
Compass
Altitude
I mentioned this on the other thread.
https://www.defender2.net/forum/topic90257-15.html
Stinger are no longer advertising the OBD2 function as compatible with Defenders because they are having so many problems with it. Pre 2011 won’t work at all with OBD2. Some post 2011 vehicles have the features, but not all and they don’t know why. As for the off-road data, my guess is that is gathered from the head unit and not OBD2. It should be easy enough to check the specs to find out. WARNING.
Post #1027007 6th Mar 2024 2:13pm
Landy addict
Thanks just read that post didn’t see that earlier Embarassed when I was trying to search for info, so many subjects on this forum that’s what makes it a great forum. For guy’s like me it’s not so easy to find stuff especially when I don’t really know what I am looking for Cool . I do like the look of the unit & think it would make it easier to see information without taking eyes off the road too much. Was hopeful that someone might know how to update my Defender to the same as the post 2011 Defender
Post #1027010 6th Mar 2024 2:26pm
That’s the Stinger unit, it does connect to the OBD2 as I’ve seen that in the specs.
It will fit the 2.4 and the 2.2, the 2.2 has a different connection plug to the rear as the 2.4 is DIN ISO and the 2.2 has its own fitting, can get an adaptor for to DIN ISO.
I’d imagine the 2.2 connector has other transmissible data.
I was under the impression the head would be connected to a DIN ISO connector, and additional connector down to the OBD2 for both the 2.4 and 2.2.
I am assuming here that the 2.4 07 to 12 version is DIN ISO, and OBD2
And the 2.2 12 to 16 version dedicated connection for a 2.2 plug and play, and OBD2.
Remember here that the OBD2 is a separate connector to the HU connector, of which the latter here is different between the 2.4 and 2.2.
I’d imagine that the difference is because of the LR OBD2 system, rather than the unit.
Can anyone confirm what live data the 2.4 has? Evidently the 2.2 has it.
Is there any kind of bug due to remaps, perhaps it is based on LR data map?
Pete @ BAS or Gary @ Alive can likely confirm, I’d imagine OBD2 live data is different though separate to performance tuning. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027045 6th Mar 2024 10:21pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I understand that Land Rover fitted a different wiring loom (Apparently more reliable) on all Defenders post 2012 I think the Puma 2.2 might have been the key identifier as to which derivative. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1027164 7th Mar 2024 3:15pm
Landy addict
That is a lot of info I don’t really understand Razz So from what I understand you are saying there is a connection difference between the 2 production dates, does this mean that the software might be the same
Post #1027271 8th Mar 2024 12:38pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Basically:
a) To connect the unit to power supply and loudspeakers there is a connector in the loom behind the radio. That connector has changed at some point (from a standardised ISO type to a Ford-specific type which you can get an ISO adapter for)
b) Everything in your first photo can be calculated by any modern smartphone (GPS, accelerometers)
c) Everything in your second photo requires reading values from the car's systems. That's done via the OBD2 connector under the steering wheel. While the connector itself is always the same, some measurement values are standardised but other may differ between models.
Only c) may require a different software (or one version which can handle the variants).
Post #1027323 8th Mar 2024 8:09pm
^^^^ This.
The connector behind the centre dash for the head unit / radio changed in 2012 which is when the 2.2 came in.
2007 to 12’ is DIN ISO which is industry standard for aftermarket Head Units and radios so plugs straight in.
2012 to 2016 LR fitted a connector of their own (grey plug), you can’t just plug into this, you can fit an adaptor to convert it back to DIN ISO, and thus then fit straight in an aftermarket head unit.
I’d imagine Stinger either include an adaptor for 12’ to 16’ years, or the system has a plug in socket or plug that plugs straight in for that year.
As mentioned, OBD2 plug is in a separate location.
Which connections does the 2.2’s grey plugs have? Is it power and speaker connections the same as DIN ISO or does it have other connections? I’m assuming it’s only audio and audio power related. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027326 8th Mar 2024 8:26pm
macfrank
Same as ISO.
This is the adaptor:
The connector in situ:
and removed - left to car, right to radio
Post #1027330 8th Mar 2024 8:50pm
Looks to be audio dedicated, power and speaker connections, so the other data is picked up from the ODB2 socket it seems for both 2.2 and 2.4 I’d imagine.
Pics are useful for anyone wondering what a 2.2 adaptor looks like. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027336 8th Mar 2024 9:24pm
Landy addict
So I have these ISO I’m guessing, so jus need to find the OBD2 now
Post #1027339 8th Mar 2024 10:19pm
Yes, that’s DIN ISO 2.4 TDCI yrs 2007 to 2012 which plugs directly into nearly all aftermarket head unit / radios directly.
One plug is primary power, the other speaker connections. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1027378 9th Mar 2024 1:32pm
macfrank
As I said: fuse box under the steering wheel.
Post #1027399 9th Mar 2024 4:52pm
