Home > P400e Area (L663) > P400e questions |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Trunk/boot size is rubbish and the hump in the floor is very annoying - I've had stuff fall out when you open the door as its sitting on the slope of the hump. My cable just lives in there in its bag and the jack is strapped to the floor on the right side. (I don't have the side carrier.)
6th Mar 2024 11:51am |
ardevd Member Since: 04 Mar 2024 Location: Norway Posts: 15 |
Yeah I’d actually rather have them raise the floor to the peak of the hump and give us some clever storage space underneath for cables and accessories than have the bulging hump on the floor.
Considering I just ordered the car your feedback on the boot is a bit concerning but I’m hoping I can make do with it regardless. Especially with the gear carrier to help me out |
6th Mar 2024 1:16pm |
Louis-C Member Since: 22 Jul 2022 Location: Essex Posts: 16 |
I've put both the Type 2 charing cable and the yellow 3 pin plug cable in my side gear carrier with no issues at all.
The Jack and all those after parts are kept in a sort of bag that is tied to the right side of the boot. I did think the boot was pretty rubbish, so I bought a full height partition cage which doubled the height of the space. I can now throw also anything in there. I have stopped moaning about the boot space after getting a 90 as a loan car. The glove box have more room than the boot in a 90 |
6th Mar 2024 8:46pm |
Do you have a link to that partition shelf?
6th Mar 2024 9:45pm |
milesg7 Member Since: 13 Sep 2023 Location: Cheltenham Posts: 61 |
I too have used the side gear carrier for cables, tow ropes, etc and it takes it all. I have a 'lashing' LR bag, https://www.mm-4x4.com/land-rover-ripstop-bag-26272-p.asp on either side of the boot area attached with a carabiner which has seat covers, a cleaning kit in them, leaves more than enough space for me. North face do small bags called Canisters, I have one of those attached to inside of the load space with phone and macbook chargers for when I am on the go.
Click image to enlarge |
6th Mar 2024 9:49pm |
https://store.landrover.com/vples0611-loadspace-partition.html |
6th Mar 2024 9:57pm |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 29 |
I bought the parcel shelf from Powerful Uk (think its Britpart that makes them) and a partition net to use the full height (the net because then it can be removed in seconds when I need to). Shelf is great for charging cable storage etc and the jack could be strapped to it also.
Regarding the partition the poster above me recommended I would instead go with the half height one linked below if you don't intend to transport dogs with the back seat folded forward. With this one you can load things straight through without having to remove it. Like the net I've got but more sturdy. https://www.lrparts.net/vehicle/the-all-ne...d-rover.ht Click image to enlarge 2024 Defender 110 p400e HSE 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
2nd Apr 2024 3:45pm |
