![]() | Home > In Car Electronics > What's going on here? |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1355 ![]() ![]() ![]() |
Its a Defender and someone has customized it. We don't know what's going on with a random wire, unraveling the shoddy workmanship of all the previous owners is part of the joy of owning a defender.
All details on factory wiring and plugs etc can be found here https://www.lrworkshop.com |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Best to identify the circuits concerned and then you’ll be 90% sure as to where to look the other end and any items attached to it or and wiring added to that circuit.
I’d imagine it’s a bypass of some kind, possibly if you remove it something won’t work. Try it and see what happens, but it shouldn’t be there it’s probably a temporary fix. Before you remove it take not of exactly where it cam from. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
As above, make note of where it is then pull it out and see what happens...
