Home > Tdi > TDI 200 Fuel Injector Pump
Page 6 of 6 <123456
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Ok, thank you for the tips and the difflock gaiter part number too!
I cannot remember, but I don't think I did, as I did not read and go through the rules. Razz
Oh, is it Santori black? If yes, it could be me, as I did pass by there, and I am from the Klang area, hehe...
Post #1023623 5th Feb 2024 8:58am
Dinnu
Unfortunately no not Santorini. It was more of a light brown colour. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1023679 5th Feb 2024 6:28pm
cykoh85
Oh. you will see mine one day..haha..It seems like there are quite a number of Defenders in the town.
Post #1023738 6th Feb 2024 2:29am
cykoh85
Hi Bro Dinnu, good day to you.
Gonna ask few questions:
Is there an oil leak in the turbocharger (as indicated by the red circle in the attached photo)?
I observed engine oil leaks (as highlighted by the yellow circle in the attached photo).
I observed some grease forming around the rear wheel, particularly near the hub (where I have a spacer). My question is, could this grease be coming from the rear drum brake area?
thank you.
Post #1024794 15th Feb 2024 3:05pm
Dinnu
The first phote, red circled looks dry enough to me.
The 2nd photo, yellow circle looks clean. But I see some hint of corrosion on the aluminum hard pipe, and corrosion is porous so some oil can leak. A small leak from the turbosharger is acceptable as long as you are not loosing too much engine oil.
Grease at hub? Perhaps a split dust cap on the drive member? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1024818 15th Feb 2024 8:25pm
cykoh85
Hahaha, it appears clean in the photo because I cleaned it before taking the picture (I forgot to take the photo before cleaning it).
Anyhow, I captured another image (please see the photo), but this is from the other side. I'm not sure where the leaks are coming from. Could it be the blue silicone hose?
As for the aluminum hard pipe, now I remember it was painted with anti-rust coating, if I'm not mistaken. I can't recall it clearly.
For the rear wheel side, please refer to the attached photo. I noticed some grease forming in the area marked with a red circle. The blue circle indicates the spacer.
Post #1024997 17th Feb 2024 2:08pm
cykoh85
Post #1025598 22nd Feb 2024 2:26pm
Dinnu
I would not worry about the oil around the turbo pipes. As long as engine oil level is not dropping too fast or you are getting white smoke.
Regarding the oil around the brake drum and its back plate, most probably is a leaking brake slave cylinder - brake fluid (am I allowed to use the slave word?) as the oil stain is high up. But need investigation and ensure it is not a hub seal - gear oil. Brake fluid and gear oil have different smell.
Either way, should investigate at the earliest as that rear corner, brake is ineffective. Its a good idea to replace the shoes once they get contaminated with oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1025632 22nd Feb 2024 8:21pm
cykoh85
Okay, noted for the turbo pipes. So far, the engine oil level is still maintained at a good level.
For the rear wheel side, it's not really oil; it's more like a grease form. Anyway, I will monitor and see how it goes first.
Thanks bro.
Post #1025682 23rd Feb 2024 10:14am
cykoh85
Hi Dinnu, just add one more photo of the turbo pipe leaks. I'm not sure if it's bad or just not good.
It appears that there is some engine oil in the area marked by the blue circle. Is this the cylinder head area (gasket) - red circle and caused the leaks? or normal?
thank you.
Post #1026022 26th Feb 2024 3:18pm
Dinnu
There seems to be some leakage within the layers of the turbo hose. Probably it is delaminating and failing.
Yes, that is the head gasket area. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1026041 26th Feb 2024 5:32pm
cykoh85
Ok, I will change the hose and see how it goes first.
By the way, for the cylinder head (marked in the RED Circle), do you know the function of the bolt? I checked again just now, and it seems like the leak is coming from the bolt and nut there.
thank you.
Post #1026145 27th Feb 2024 2:34pm
Dinnu
If I remember correctly, that bolt holds that valve tappet guide. Unsure if the guide can drop if you take that bolt out. There should be an aluminum washer under the bolt. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1026167 27th Feb 2024 5:35pm
cykoh85
Okay, thanks for the information.
I double-checked with a friend in Kelantan, and he mentioned that the bolt cannot be removed because there is a copper part that may fall out. Removing the bolt could lead to the piston breaking.
Post #1026262 28th Feb 2024 3:51pm
Page 6 of 6 <123456
