![]() | Home > My Defender > 110 CSW Td5 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
Awesome
Chriswb84 Member Since: 16 Sep 2023 Location: North West Posts: 25 ![]() ![]() ![]() |
February job list involved replacing front discs, pads and rebuilding the front calipers. Just as some context I don't do any of this for a living so I just go off what I picked up, read or my dad teaching me when we built an MK kit car and various other automotive work in the past. With that in mind I do make some mistakes which some might wonder why or how!
Okay so jacked up the front of the car, went to remove the first caliper bolt and it rounded, it was so rusted up it had no shape, I think the 12 point bolts don't last very long with corrosion from what I can see. Tried the other and it did the same, so I was a bit stuck then. I should have gone and bought a stud remover but I didn't. Ended up cutting the caliper in half with a disc cutter so I could drill out the studs in the steering housing. This failed miserably so took the steering housing off, bought a new one and a new caliper. Whilst I was there I took off the swivel ball and replaced all the gaskets and seals, bearings etc. The brake line was badly corroded and paper thin so it just twisted off as I removed the union from the flex hose. I bought a brake flare kit and made a new line up on the drivers side. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Bit more wise now on what to expect, so on the passenger side, I removed the caliper flex hose, removed the hub locking nut and the housing swivel seal and pulled the whole unit off in one go. I could then try to get the caliper off without rounding the nuts, but they rounded anyway. So cheap set of stud removers from Toolstation and I had the caliper off the housing. Now just to rebuild the caliper and steering housing etc. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Swivel ball was corroded so had to replace that but, all back on the road and up and running with much better braking than before I started, so not a complete waste of time. ![]() Click image to enlarge |
Thank you for the detailed update, 10/10 for the work carried out and i have been there like you with " learning by your mistakes " you do get a wealth of knowledge when maintaining these vehicles which does help you in the future
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Cracking job that! Love to see a kitchen table loaded up with oily rags and Defender parts!
It was half term, wife was in work so had no idea. She did question why there were little black spots of paint on the surface. I just said we spend the afternoon crafting.
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Hello folks, I haven't posted much. Failed my MOT in March due to steering ball joint but sorted that and it's not noteworthy.
More recently I rebuilt the starter solenoid using the rebuild kit which was easy enough apart from getting it out of the bell housing. Also fitted Glywn Lewis rear mud flaps shields on the arches. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
great stuff, my dad has a caravan too, due to the weight of it, it was one of the reasons they switched to the Jeep and then later the defender. the peugeot 406 Turbo diesel they had could just say tow it! My mam has hinted on taking mine away, if their Defender is not ready. I am like don't be daft! they already running about in my peugeot 306, for the last 6 months. ( that my dad said it should be scrapped, when the fuel pump went on it)
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
My dad used to tow a caravan behind a Rover 416, and he said it struggled. They then swapped the car to a Maestro 2L Turbo diesel which I think he said was a Gardner engine but I cant find any reference online to this, but he recons was brilliant at towing.
We are planning to be in Cornwall this year, and have had a couple of long weekend in Anglesey already. Trying to get the most out of it really when the weather isn't too bad and we have the time. So I usually try to get some of the pressing jobs out the way before going anywhere really. I had all the earth points off last night, cleaned the contact points on the chassis etc and replaced the nuts/washers with new as the old ones were rusting up, I think it is causing a few issues when starting. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
Those Gynn Lewis shields look the business.
The engine in the Maestro - would it be a Perkins Prima engine? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
The shields are really good I have all the Gwyn Lewis shields installed, first one is a pain to do but once figured out the second arch is done in no time! I just covered the Galvanised metal work which comes into contact with the Alu body in PVC tape and Tigerseal. I read somewhere Zinc and Alu are even more reactive than Steel on Alu.
Searching online about the Maestro as it reminded me writing this up, your right excossack its the Perkins engine or L series Rover engine, the one we had was the turbo version and it was rapid for the day. I remember the turbo kicking in and my dad pointing it out, I must have been about 6 or 7 years old at the time. For anyone interested I found this on the wiki page - "The L-series was extremely versatile and has been fitted in the Land Rover Freelander, Rover 200 Mk3, Rover 400 Mk2, Rover 600, and European versions of the Honda Accord and Honda Civic. It has been successfully tuned to produce much higher power than standard." https://en.wikipedia.org/wiki/Rover_L-series_engine |
Green_90 Member Since: 23 Apr 2025 Location: Herefordshire Posts: 3 ![]() ![]() |
Great job tidying the truck up.
I have a 2000 TD5 90 that is undergoing the same treatment; although I am having woes with paint colour... What shade & where did you end up getting the paint from? It looks a good match. |
Hi, thanks for the interest, its colour code LRC637 Conniston Green, which I order from Colourtone in Southport. I cant do the whole body in one go, so I tend to just tackle the local corrosion, use gaskets etc to seperate the metals then re-paint. I also found that replacing nuts and bolts as I go along is really inexpensive and makes a huge difference.
I havent updated my threat for a bit so I might just load up some recent updates etc. Good luck with your build. |
Bit of an update as I havent added much recently.
Added Carpet to the interior, removed the rear seats and filled the holes. Lots of galvanic corrosion going on with those. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Then replaced the bench seats, never use them on the road but handy when using the back of the fender as a mobile brew station. ![]() Click image to enlarge Track Rod ends were worn, I could imagine how much fun removing them would be so I just replaced the rod ends with greasable and new steering arms from Glwyn Lewis. Brilliant and supprisingly heavy. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Started to tidy up the rear quater pannels as they are blistering a lot, removed the end capping and re-painted, sanded back and re-sprayed. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
