![]() | Home > Faults & Fixes (L663) > Water noise |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 25 ![]() ![]() |
I had to remove a rubber grommet from the underside to drain it
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
You need to find out where its getting in - because I am sure long term that wont be good...
back to the dealer.. |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
There’s a known SSM for water ingress mine is getting something done next time it goes in but they didn’t say where it was.
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Water ingress is in the DNA of all Defenders.....
Mines going in on the 16th for various faults/fixes will update on the water ingress then.
Will book it in and also see if they can sort out the SIM card not always working for online services 🤞
Archon Member Since: 26 Feb 2024 Location: Wales Posts: 2 ![]() ![]() |
Resurrecting an old post... was this ever sorted? After hearing sloshing i took the grommet out and gallons poured out
It's going in tomorrow by chance anyway and still by a whisker in warranty Any help gratefully received First post so please be gentle thanks |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Might be beneficial to leave the drain grommet out until the issue is sorted. 1982 88" 2.25 diesel
Yes, thanks, done that. Problem is grommet isnt at lowest point so there’s still a reservoir behind
Probably seems like heresy saying this, but would it be feasible to drill a hole at the lowest point to stop water building up? Just make the diameter the same as the existing whole and you can plug it with a grommet when the issue is solved. If you do drill a new hole do not for get to put some paint on the new edges to stop it rusting. 1982 88" 2.25 diesel
